You are currently viewing GNU Radio to Web client
As part of the “Remote SDR” project, it is necessary to extract the audio channel data created by GNU Radio from the “Remote SSB receiver” and send it to a Web client.
Among the processing blocks present in GNURADIO-companion, there is the UDP sink block for outputting the data. To enter an audio data stream into a web page, you can use websockets. The program proposed below in python 3, retrieves the audio stream received from GNU radio according to the UDP protocol (port 9001) and passes this data to the web client according to the websocket protocol (port 8001). We exchange 1024 byte packets. You should not make them too important so as not to delay the audio signal. Here the audio is coded on 2 bytes. We thus send 512 samples, knowing that we are sampled at 10kHz, that makes about 50ms of signal.
#!/usr/bin/python3           # This is client.py file
#Collect of Audio data from GNU Radio and send to web client
#Recuperation des données audio  de GNU_Radio et envoi vers le client web
import socket
import asyncio
import websockets
# create a socket object
# get local machine name
host = 'localhost'
port_audio_Web = 8001
port_audio_GR = 9001
s_audio.bind((host, port_audio_GR))
print ("Passerelle audio Web")
# Receive no more than 1024 bytes audio
    while True:
# on recupere les data de GNU-RADIO
        msg_audio = s_audio.recv(1024)
#       print ("audio",len(msg_audio))
# on envoi le message vers le client web distant
        await websocket_a.send(msg_audio)
For sending the spectrum to create a waterfall on the web page, we use another program very similar to that of audio. Knowing that a spectrum is described at the output of FFT by 1024 points each represented by 2 bytes, we will send packets of 2048 bytes.
#Collect spectral data to be passed to a web client
#Recuperation des données  spectre de GNU_Radio et envoi vers le client web
import socket
import asyncio
import websockets
s_spectre = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
host = 'localhost'
port_spectre_Web = 8002
port_spectre_GR = 9002
s_spectre.bind((host, port_spectre_GR))
print("Passerelle Spectre vers client WEB")
# Reception 2048 bytes du spectre
async def spectre(websocket_s, path):
    while True:
        msg_spectre = s_spectre.recv(2048)
#       print ("spectre",len(msg_spectre))
        await websocket_s.send(msg_spectre)
start_server_spectre = websockets.serve(spectre, "", port_spectre_Web)
asyncio.get_event_loop().run_until_complete(start_server_spectre)
The source files are available on Github F1ATB / Remote-SDR.
Posts on Remote-SDR
