Je souhaite me lancer... - Version imprimable +- F1ATB forum (https://f1atb.fr/forum_f1atb) +-- Forum : Forum de F1ATB (https://f1atb.fr/forum_f1atb/forum-3.html) +--- Forum : Domotique (https://f1atb.fr/forum_f1atb/forum-6.html) +--- Sujet : Je souhaite me lancer... (/thread-2234.html) |
RE: Je souhaite me lancer... - Seb57 - 10-02-2026 Du coup je pense aller au plus simple... Mesure via Shelly pro em Traitement via ESP32 sur support Actionneur SSR 40A Ma liste de matériel: Alimentation: https://fr.aliexpress.com/item/1005009569618850.html?spm=a2g0o.cart.0.0.240a378dTODKoH&mp=1&pdp_npi=6%40dis%21EUR%21EUR%207.21%21EUR%203.19%21%21EUR%203.16%21%21%21%40211b629217707423407816623e3475%2112000049491764679%21ct%21FR%21181795855%21%211%210%21&gatewayAdapt=glo2fra SSR: https://fr.aliexpress.com/item/1005006953580553.html?spm=a2g0o.cart.0.0.240a378dTODKoH&mp=1&pdp_npi=6%40dis%21EUR%21EUR%203.92%21EUR%203.89%21%21EUR%203.89%21%21%21%40211b629217707423407816623e3475%2112000047719322845%21ct%21FR%21181795855%21%211%210%21&gatewayAdapt=glo2fra ESP32: https://fr.aliexpress.com/item/1005007804467274.html?spm=a2g0o.cart.0.0.240a378dTODKoH&mp=1&pdp_npi=6%40dis%21EUR%21EUR%206.89%21EUR%206.89%21%21EUR%206.89%21%21%21%40211b629217707423407816623e3475%2112000042258766903%21ct%21FR%21181795855%21%211%210%21&pdp_ext_f=%7B%22cart2PdpParams%22%3A%7B%22pdpBusinessMode%22%3A%22retail%22%7D%7D&gatewayAdapt=glo2fra Coffret: https://fr.aliexpress.com/item/1005010040247770.html?spm=a2g0o.cart.0.0.57d4378d7tqut8&mp=1&pdp_npi=6%40dis%21EUR%21EUR%2035.49%21EUR%2017.39%21%21EUR%2017.22%21%21%21%40210390c917707529538276721eed8c%2112000050917455751%21ct%21FR%21181795855%21%211%210%21&gatewayAdapt=glo2fra LED: https://fr.aliexpress.com/item/1005008907425295.html?spm=a2g0o.cart.0.0.5c48378dOZyD9k&mp=1&pdp_npi=6%40dis%21EUR%21EUR%204.24%21EUR%202.08%21%21EUR%202.06%21%21%21%40211b61ae17707536580877557e8ca4%2112000047150432016%21ct%21FR%21181795855%21%211%210%21&gatewayAdapt=glo2fra https://fr.aliexpress.com/item/1005003450521741.html?spm=a2g0o.cart.0.0.5c48378dOZyD9k&mp=1&pdp_npi=6%40dis%21EUR%21EUR%201.19%21EUR%201.19%21%21EUR%201.18%21%21%21%40211b61ae17707536580877557e8ca4%2112000025845403138%21ct%21FR%21181795855%21%211%210%21&gatewayAdapt=glo2fra Antenne: https://fr.aliexpress.com/item/1005007039901040.html?spm=a2g0o.cart.0.0.240a378dTODKoH&mp=1&pdp_npi=6%40dis%21EUR%21EUR%201.01%21EUR%201.01%21%21EUR%201.01%21%21%21%40211b629217707423407816623e3475%2112000039183659741%21ct%21FR%21181795855%21%211%210%21&gatewayAdapt=glo2fra Pate thermique: https://fr.aliexpress.com/item/1005010208101136.html?spm=a2g0o.cart.0.0.1014378d9okOj7&mp=1&pdp_npi=6%40dis%21EUR%21EUR%203.62%21EUR%201.66%21%21EUR%201.64%21%21%21%40211b807017707526807357484e6ca0%2112000051550270961%21ct%21FR%21181795855%21%211%210%21&gatewayAdapt=glo2fra Dissipateur: https://fr.aliexpress.com/item/1005011619431291.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.6.5a2b2nAE2nAEfq&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40050.354490.0&scm_id=1007.40050.354490.0&scm-url=1007.40050.354490.0&pvid=d5b09db8-87f4-4069-ba0e-f8ed7f5f2a27&_t=gps-id:pcDetailTopMoreOtherSeller,scm-url:1007.40050.354490.0,pvid:d5b09db8-87f4-4069-ba0e-f8ed7f5f2a27,tpp_buckets:668%232846%238107%231934&pdp_ext_f=%7B%22order%22%3A%223%22%2C%22spu_best_type%22%3A%22price%22%2C%22eval%22%3A%221%22%2C%22sceneId%22%3A%2230050%22%2C%22fromPage%22%3A%22recommend%22%7D&pdp_npi=6%40dis%21EUR%2111.74%213.49%21%21%2194.30%2128.04%21%402103849717707531301883926ef4d0%2112000056069853152%21rec%21FR%21181795855%21X%211%210%21n_tag%3A-29919%3Bd%3A76ea95a2%3Bm03_new_user%3A-29895%3BpisId%3A5000000200404592&utparam-url=scene%3ApcDetailTopMoreOtherSeller%7Cquery_from%3A%7Cx_object_id%3A1005011619431291%7C_p_origin_prod%3A J'ai également mis un cordon USB TypeC de 10cm dans mon panier. Ma liste vous semble correcte? RE: Je souhaite me lancer... - Sgb31 - 10-02-2026 Salut, Ok, ton lien pate thermique est le même que l'antenne boitier un peu juste. si tu prends assez grand pour bien positionner les éléments sans risque du coup prends un dissipateur le plus grand possible ( en fct du boitier bien sûr) Attention, les leds sont assez grosses pense aux cables dupont, cable alim.. RE: Je souhaite me lancer... - Seb57 - 10-02-2026 (10-02-2026, 07:41 PM)Sgb31 a écrit : Salut, J'ai mis à jour le panier, tu en penses quoi? Concernant le câble pour l'alimentation et la connexion au chauffe-eau, j'ai ce qu'il faut. Je pense que le câble Dupont n'est pas nécessaire car j'aurai les connectiques à visser au niveau de l'embase de l'ESP32 et du SSR. Concernant les LED je pensais effectuer la connexion par soudure avec un morceau de gaine thermo dessus. RE: Je souhaite me lancer... - Lolo69 - 10-02-2026 Les leds sont elles vraiment utiles ? Perso je ne les ai pas mise et ça me manque pas… ainsi avec montage esp sur embase à vis + ssr + Shelly = routeur avec zéro soudure 4 fils à brancher = routeur qui fonctionne depuis 24 mois sans aucune panne. Attention si tu mets l antenne externe il faut dessouder le tout petit shunt pour supprimer antenne interne. RE: Je souhaite me lancer... - Seb57 - 11-02-2026 (10-02-2026, 10:25 PM)Lolo69 a écrit : Les leds sont elles vraiment utiles ? Perso je ne les ai pas mise et ça me manque pas… ainsi avec montage esp sur embase à vis + ssr + Shelly = routeur avec zéro soudure 4 fils à brancher = routeur qui fonctionne depuis 24 mois sans aucune panne. Je préfère mettre les LED rien de compliqué. Merci pour l'information concernant l'antenne. RE: Je souhaite me lancer... - Sgb31 - 11-02-2026 (10-02-2026, 10:25 PM)Lolo69 a écrit : Les leds sont elles vraiment utiles ? Perso je ne les ai pas mise et ça me manque pas… ainsi avec montage esp sur embase à vis + ssr + Shelly = routeur avec zéro soudure 4 fils à brancher = routeur qui fonctionne depuis 24 mois sans aucune panne. @lolo69 : Ha bon ? j'utilise depuis pas mal de temps les esp avec antenne et je n'ai jamais dessouder le petit shunt dont tu parles ! tu est sûr de ton coup ? je ne me souviens pas avoir lu cette info ... RE: Je souhaite me lancer... - Lolo69 - 11-02-2026 Ca depend de quel côté est le shunt. Si esp vendu avec esp on peut supposer que le shunt est du bon coté. Si vendu séparément c est sur que le shunt est du mauvais coté RE: Je souhaite me lancer... - Sgb31 - 11-02-2026 Lolo : tu aurais une photo pour illustrer cela ? RE: Je souhaite me lancer... - Lolo69 - 11-02-2026 Oui je te la mettrai mais attention c est minuscule , avec mes yeux de soixantenaire même avec gros zoom j ai beaucoup de mal à voir et donc encore moins changer le shunt de côté !! Sur ce site on voit bien et c est bien expliqué https://www.google.com/imgres?imgurl=https%3A%2F%2Fwww.raspberryme.com%2Fwp-content%2Fuploads%2F2022%2F01%2F1641626644_105_Antenne-externe-ESP32-CAM-Connect-extension-de-la-couverture-Wi-Fi.jpg&tbnid=h6_itto5wcl_6M&vet=1&imgrefurl=https%3A%2F%2Fwww.raspberryme.com%2Fantenne-externe-esp32-cam-connect-extension-de-la-couverture-wi-fi%2F&docid=W4m8jBxO310lFM&w=828&h=334&hl=fr-fr&source=sh%2Fx%2Fim%2Fm4%2F0&kgs=2ab8fbfba52e5eee RE: Je souhaite me lancer... - Sgb31 - 11-02-2026 HA oui, en effet, c'est hyper petit et idem avec les soixante balais , faut vraiment prendre la loupe et encore sur deux esp32 que j'ai , j'ai du mal à voir ... merci lolo ;-) ! |
