Hello
I have tried to use Remote SDR but I wasn't able to get my HackRF working with it. I was not able to select it in Settings. No idea what I am doing wrong?
Remote SDR running version : 5.08
hackrf_info version: unknown
libhackrf version: unknown (0.5)
Found HackRF
Index: 0
Board ID Number: 2 (HackRF One)
Firmware Version: 2014.08.1 (API:1.00)
Part ID Number: 0xa000cb3c 0x0053475b
Error: /remsdr/EJS/Ajax/tools.ejs:2
1| <div style='width:100%;background-color: black;color:white;'>
>> 2| <%
3| function ReadFile(F){
4| try {
5| var data = fs.readFileSync(F, 'utf8');
Command failed: SoapySDRUtil --probe="driver=hackrf"
[INFO] Opening HackRF One #0 14d463dc0f3d4be1...
[INFO] Could not Open HackRF Device
Error probing device: hackrf open failed
at checkExecSyncError (node:child_process:828:11)
at Object.execSync (node:child_process:902:15)
at eval ("/remsdr/EJS/Ajax/tools.ejs":91:18)
at tools (/remsdr/node_modules/ejs/lib/ejs.js:692:17)
at tryHandleCache (/remsdr/node_modules/ejs/lib/ejs.js:272:36)
at View.exports.renderFile [as engine] (/remsdr/node_modules/ejs/lib/ejs.js:489:10)
at View.render (/remsdr/node_modules/express/lib/view.js:135:8)
at tryRender (/remsdr/node_modules/express/lib/application.js:640:10)
at Function.render (/remsdr/node_modules/express/lib/application.js:592:3)
at ServerResponse.render (/remsdr/node_modules/express/lib/response.js:1017:7)
Sujets : 36
128
Often, it's a problem of 5V power supply or USB cable.
The solution was HackRF Firmware Update.
I had run the 2014.08.1 (API:1.00),
now its the 2024.02.1 (API:1.08)
and it works.
08-07-2024, 08:30 PM
(Modification du message : 09-07-2024, 11:07 PM par Cupro.
Raison de la modification: grammer
I will reuse my own thread ^^
I am using only the RX Configuration and it worked fine, but from yesterday RX stops working after 30 seconds. In this time everything is great.
Restarting with the Icon on the upper left helps.
19:5:26 : Start Server on port 80 in http and port 443 in https.
19:19:31 : OE4CUP/MacBook> ms : 201 | RXsocket.connected
19:19:31 : OE4CUP/MacBook> ms : 201 | Define IP adresses
19:19:33 : OE4CUP/MacBook> ms : 271 | RXsocket.connected
19:19:33 : OE4CUP/MacBook> ms : 271 | Define IP adresses
19:19:33 : OE4CUP/MacBook> ms : 271 | RXsocket.io connected
19:19:33 : CPU> Launch RX: hackrf, RxSampRate: 3000000
19:19:33 : CPU> Launch TX: none, TxSampRate: 0
19:19:33 : OE4CUP/MacBook> ms : 696 | TX ready:false TX SDR:none
19:19:34 : OE4CUP/MacBook> ms : 1304 | RX configuration received
19:19:34 : OE4CUP/MacBook> ms : 1498 | TX configuration received
19:19:34 : OE4CUP/MacBook> ms : 1512 | Valide Local_Storage true
19:19:34 : OE4CUP/MacBook> ms : 1513 | Recall Rx parameters
19:19:34 : OE4CUP/MacBook> ms : 1522 | Recall_SDR_Para()
19:19:34 : OE4CUP/MacBook> ms : 1523 | Init Sliders
19:19:34 : OE4CUP/MacBook> ms : 1536 | Init_Page_RX()
19:19:34 : OE4CUP/MacBook> ms : 1537 | RX parameters init
19:19:34 : OE4CUP/MacBook> ms : 1538 | Init_Page_TX()
19:19:34 : OE4CUP/MacBook> ms : 1542 | TX Start New Mode
19:19:34 : CPU> connected to RX Spectra server!
19:19:34 : CPU> connected to RX Audio server!
19:20:15 : CPU> Kill RX: hackrf
19:20:22 : OE4CUP/MacBook> ms : 118 | RXsocket.connected
19:20:22 : OE4CUP/MacBook> ms : 119 | Define IP adresses
19:20:24 : OE4CUP/MacBook> ms : 23 | RXsocket.connected
19:20:25 : OE4CUP/MacBook> ms : 23 | Define IP adresses
19:20:25 : CPU> Launch RX: hackrf, RxSampRate: 3000000
19:20:25 : CPU> Launch TX: none, TxSampRate: 0
19:20:25 : OE4CUP/MacBook> ms : 448 | TX ready:false TX SDR:none
19:20:27 : OE4CUP/MacBook> ms : 79 | RXsocket.connected
19:20:27 : OE4CUP/MacBook> ms : 79 | Define IP adresses
19:20:29 : OE4CUP/MacBook> ms : 189 | RXsocket.connected
19:20:29 : OE4CUP/MacBook> ms : 190 | Define IP adresses
19:20:34 : CPU> Kill RX: hackrf
19:20:53 : OE4CUP/MacBook> ms : 104 | RXsocket.connected
19:20:53 : OE4CUP/MacBook> ms : 104 | Define IP adresses
19:20:55 : OE4CUP/MacBook> ms : 106 | RXsocket.connected
19:20:55 : OE4CUP/MacBook> ms : 106 | Define IP adresses
19:20:55 : OE4CUP/MacBook> ms : 106 | RXsocket.io connected
19:20:55 : CPU> Launch RX: hackrf, RxSampRate: 3000000
19:20:56 : CPU> Launch TX: none, TxSampRate: 0
19:20:56 : OE4CUP/MacBook> ms : 273 | TX ready:false TX SDR:none
19:20:56 : OE4CUP/MacBook> ms : 347 | RX configuration received
19:20:56 : CPU> connected to RX Audio server!
19:20:56 : OE4CUP/MacBook> ms : 370 | TX configuration received
19:20:56 : OE4CUP/MacBook> ms : 391 | Valide Local_Storage true
19:20:56 : OE4CUP/MacBook> ms : 391 | Recall Rx parameters
19:20:56 : OE4CUP/MacBook> ms : 392 | Recall_SDR_Para()
19:20:56 : OE4CUP/MacBook> ms : 393 | Init Sliders
19:20:56 : OE4CUP/MacBook> ms : 413 | Init_Page_RX()
19:20:56 : OE4CUP/MacBook> ms : 414 | RX parameters init
19:20:56 : OE4CUP/MacBook> ms : 415 | Init_Page_TX()
19:20:56 : OE4CUP/MacBook> ms : 418 | TX Start New Mode
19:20:56 : CPU> connected to RX Spectra server!
19:21:36 : CPU> Kill RX: hackrf
19:21:38 : OE4CUP/MacBook> ms : 108 | RXsocket.connected
19:21:38 : OE4CUP/MacBook> ms : 109 | Define IP adresses
19:21:40 : OE4CUP/MacBook> ms : 21 | RXsocket.connected
19:21:40 : OE4CUP/MacBook> ms : 21 | Define IP adresses
19:21:40 : CPU> Launch RX: hackrf, RxSampRate: 3000000
19:21:40 : CPU> Launch TX: none, TxSampRate: 0
19:21:41 : OE4CUP/MacBook> ms : 285 | TX ready:false TX SDR:none
19:21:43 : OE4CUP/MacBook> ms : 65 | RXsocket.connected
19:21:43 : OE4CUP/MacBook> ms : 65 | Define IP adresses
19:21:45 : OE4CUP/MacBook> ms : 93 | RXsocket.connected
19:21:45 : OE4CUP/MacBook> ms : 93 | Define IP adresses
19:21:50 : CPU> Kill RX: hackrf
19:22:17 : OE4CUP/MacBook> ms : 106 | RXsocket.connected
19:22:17 : OE4CUP/MacBook> ms : 106 | Define IP adresses
19:22:20 : OE4CUP/MacBook> ms : 442 | RXsocket.connected
19:22:20 : OE4CUP/MacBook> ms : 443 | Define IP adresses
19:22:20 : OE4CUP/MacBook> ms : 443 | RXsocket.io connected
19:22:20 : CPU> Launch RX: hackrf, RxSampRate: 3000000
19:22:20 : CPU> Launch TX: none, TxSampRate: 0
19:22:20 : OE4CUP/MacBook> ms : 948 | TX ready:false TX SDR:none
19:22:21 : OE4CUP/MacBook> ms : 979 | RX configuration received
19:22:21 : OE4CUP/MacBook> ms : 1000 | TX configuration received
19:22:21 : CPU> connected to RX Audio server!
19:22:21 : OE4CUP/MacBook> ms : 1010 | Valide Local_Storage true
19:22:21 : OE4CUP/MacBook> ms : 1010 | Recall Rx parameters
19:22:21 : OE4CUP/MacBook> ms : 1012 | Recall_SDR_Para()
19:22:21 : OE4CUP/MacBook> ms : 1012 | Init Sliders
19:22:21 : OE4CUP/MacBook> ms : 1038 | Init_Page_RX()
19:22:21 : OE4CUP/MacBook> ms : 1039 | RX parameters init
19:22:21 : OE4CUP/MacBook> ms : 1039 | Init_Page_TX()
19:22:21 : OE4CUP/MacBook> ms : 1042 | TX Start New Mode
19:22:21 : CPU> connected to RX Spectra server!
19:22:23 : OE4CUP/MacBook> ms : 74 | RXsocket.connected
19:22:23 : OE4CUP/MacBook> ms : 74 | Define IP adresses
19:22:24 : CPU> Kill RX: hackrf
19:22:25 : OE4CUP/MacBook> ms : 65 | RXsocket.connected
19:22:25 : OE4CUP/MacBook> ms : 65 | Define IP adresses
19:22:46 : OE4CUP/MacBook> ms : 103 | RXsocket.connected
19:22:46 : OE4CUP/MacBook> ms : 103 | Define IP adresses
19:22:50 : OE4CUP/MacBook> ms : 435 | RXsocket.connected
19:22:50 : OE4CUP/MacBook> ms : 435 | Define IP adresses
19:22:50 : OE4CUP/MacBook> ms : 435 | RXsocket.io connected
19:22:50 : CPU> Launch RX: hackrf, RxSampRate: 3000000
19:22:51 : CPU> Launch TX: none, TxSampRate: 0
19:22:51 : OE4CUP/MacBook> ms : 651 | TX ready:false TX SDR:none
19:22:51 : OE4CUP/MacBook> ms : 679 | RX configuration received
19:22:51 : OE4CUP/MacBook> ms : 696 | TX configuration received
19:22:51 : OE4CUP/MacBook> ms : 705 | Valide Local_Storage true
19:22:51 : OE4CUP/MacBook> ms : 705 | Recall Rx parameters
19:22:51 : OE4CUP/MacBook> ms : 706 | Recall_SDR_Para()
19:22:51 : OE4CUP/MacBook> ms : 707 | Init Sliders
19:22:51 : OE4CUP/MacBook> ms : 733 | Init_Page_RX()
19:22:51 : OE4CUP/MacBook> ms : 733 | RX parameters init
19:22:51 : OE4CUP/MacBook> ms : 734 | Init_Page_TX()
19:22:51 : OE4CUP/MacBook> ms : 737 | TX Start New Mode
19:22:51 : CPU> connected to RX Audio server!
19:22:51 : CPU> connected to RX Spectra server!
19:22:53 : OE4CUP/MacBook> ms : 196 | RXsocket.connected
19:22:53 : OE4CUP/MacBook> ms : 196 | Define IP adresses
19:22:55 : OE4CUP/MacBook> ms : 22 | RXsocket.connected
19:22:55 : OE4CUP/MacBook> ms : 22 | Define IP adresses
19:22:55 : OE4CUP/MacBook> ms : 22 | RXsocket.io connected
19:22:55 : CPU> Launch TX: none, TxSampRate: 0
19:22:55 : OE4CUP/MacBook> ms : 189 | TX ready:false TX SDR:none
19:22:55 : OE4CUP/MacBook> ms : 208 | RX configuration received
19:22:55 : OE4CUP/MacBook> ms : 221 | TX configuration received
19:22:55 : CPU> connected to RX Spectra server!
19:22:55 : CPU> connected to RX Audio server!
19:22:55 : OE4CUP/MacBook> ms : 231 | Valide Local_Storage true
19:22:55 : OE4CUP/MacBook> ms : 231 | Recall Rx parameters
19:22:55 : OE4CUP/MacBook> ms : 233 | Recall_SDR_Para()
19:22:55 : OE4CUP/MacBook> ms : 233 | Init Sliders
19:22:55 : OE4CUP/MacBook> ms : 252 | Init_Page_RX()
19:22:55 : OE4CUP/MacBook> ms : 254 | RX parameters init
19:22:55 : OE4CUP/MacBook> ms : 255 | Init_Page_TX()
19:22:55 : OE4CUP/MacBook> ms : 260 | TX Start New Mode
19:23:31 : OE4CUP/MacBook> ms : 109 | RXsocket.connected
19:23:31 : OE4CUP/MacBook> ms : 109 | Define IP adresses
19:23:33 : OE4CUP/MacBook> ms : 103 | RXsocket.connected
19:23:33 : OE4CUP/MacBook> ms : 103 | Define IP adresses
19:23:36 : CPU> Kill RX: hackrf
19:24:4 : OE4CUP/MacBook> ms : 152 | RXsocket.connected
19:24:4 : OE4CUP/MacBook> ms : 152 | Define IP adresses
19:24:6 : OE4CUP/MacBook> ms : 212 | RXsocket.connected
19:24:6 : OE4CUP/MacBook> ms : 212 | Define IP adresses
19:24:6 : OE4CUP/MacBook> ms : 212 | RXsocket.io connected
19:24:6 : CPU> Launch RX: hackrf, RxSampRate: 3000000
19:24:6 : CPU> Launch TX: none, TxSampRate: 0
19:24:6 : OE4CUP/MacBook> ms : 641 | TX ready:false TX SDR:none
19:24:7 : OE4CUP/MacBook> ms : 1183 | RX configuration received
19:24:7 : OE4CUP/MacBook> ms : 1428 | TX configuration received
19:24:7 : OE4CUP/MacBook> ms : 1443 | Valide Local_Storage true
19:24:7 : OE4CUP/MacBook> ms : 1444 | Recall Rx parameters
19:24:7 : OE4CUP/MacBook> ms : 1446 | Recall_SDR_Para()
19:24:7 : OE4CUP/MacBook> ms : 1447 | Init Sliders
19:24:7 : OE4CUP/MacBook> ms : 1475 | Init_Page_RX()
19:24:7 : OE4CUP/MacBook> ms : 1475 | RX parameters init
19:24:7 : OE4CUP/MacBook> ms : 1476 | Init_Page_TX()
19:24:7 : OE4CUP/MacBook> ms : 1479 | TX Start New Mode
19:24:7 : CPU> connected to RX Spectra server!
19:24:7 : CPU> connected to RX Audio server!
19:24:46 : CPU> Kill RX: hackrf
19:25:18 : OE4CUP/MacBook> ms : 181 | RXsocket.connected
19:25:18 : OE4CUP/MacBook> ms : 182 | Define IP adresses
19:25:18 : OE4CUP/MacBook> ms : 182 | RXsocket.io connected
19:25:18 : CPU> Launch RX: hackrf, RxSampRate: 3000000
19:25:18 : CPU> Launch TX: none, TxSampRate: 0
19:25:18 : OE4CUP/MacBook> ms : 760 | TX ready:false TX SDR:none
19:25:18 : OE4CUP/MacBook> ms : 1028 | RX configuration received
19:25:19 : OE4CUP/MacBook> ms : 1303 | TX configuration received
19:25:19 : OE4CUP/MacBook> ms : 1317 | Valide Local_Storage true
19:25:19 : OE4CUP/MacBook> ms : 1317 | Recall Rx parameters
19:25:19 : OE4CUP/MacBook> ms : 1319 | Recall_SDR_Para()
19:25:19 : OE4CUP/MacBook> ms : 1320 | Init Sliders
19:25:19 : OE4CUP/MacBook> ms : 1354 | Init_Page_RX()
19:25:19 : OE4CUP/MacBook> ms : 1355 | RX parameters init
19:25:19 : OE4CUP/MacBook> ms : 1356 | Init_Page_TX()
19:25:19 : OE4CUP/MacBook> ms : 1359 | TX Start New Mode
19:25:19 : CPU> connected to RX Spectra server!
19:25:19 : CPU> connected to RX Audio server!
19:25:58 : CPU> Kill RX: hackrf
19:26:18 : OE4CUP/MacBook> ms : 93 | RXsocket.connected
19:26:18 : OE4CUP/MacBook> ms : 93 | Define IP adresses
19:26:23 : OE4CUP/MacBook> ms : 103 | RXsocket.connected
19:26:23 : OE4CUP/MacBook> ms : 103 | Define IP adresses
19:27:58 : OE4CUP/MacBook> ms : 95850 | RXsocket.connected
19:27:59 : OE4CUP/MacBook> ms : 95850 | Define IP adresses
19:28:18 : OE4CUP/MacBook> ms : 96 | RXsocket.connected
19:28:18 : OE4CUP/MacBook> ms : 96 | Define IP adresses
19:28:20 : OE4CUP/MacBook> ms : 210 | RXsocket.connected
19:28:21 : OE4CUP/MacBook> ms : 210 | Define IP adresses
19:28:21 : OE4CUP/MacBook> ms : 210 | RXsocket.io connected
19:28:21 : CPU> Launch RX: hackrf, RxSampRate: 3000000
19:28:21 : CPU> Launch TX: none, TxSampRate: 0
19:28:21 : OE4CUP/MacBook> ms : 1073 | TX ready:false TX SDR:none
19:28:21 : OE4CUP/MacBook> ms : 1289 | RX configuration received
19:28:21 : OE4CUP/MacBook> ms : 1415 | TX configuration received
19:28:21 : OE4CUP/MacBook> ms : 1431 | Valide Local_Storage true
19:28:21 : OE4CUP/MacBook> ms : 1432 | Recall Rx parameters
19:28:21 : OE4CUP/MacBook> ms : 1434 | Recall_SDR_Para()
19:28:21 : OE4CUP/MacBook> ms : 1435 | Init Sliders
19:28:21 : OE4CUP/MacBook> ms : 1462 | Init_Page_RX()
19:28:21 : OE4CUP/MacBook> ms : 1462 | RX parameters init
19:28:21 : OE4CUP/MacBook> ms : 1463 | Init_Page_TX()
19:28:21 : OE4CUP/MacBook> ms : 1466 | TX Start New Mode
19:28:21 : CPU> connected to RX Spectra server!
19:28:21 : CPU> connected to RX Audio server!
19:28:59 : CPU> Kill RX: hackrf
19:29:48 : OE4CUP/MacBook> ms : 165 | RXsocket.connected
19:29:48 : OE4CUP/MacBook> ms : 166 | Define IP adresses
19:29:51 : OE4CUP/MacBook> ms : 117 | RXsocket.connected
19:29:51 : OE4CUP/MacBook> ms : 117 | Define IP adresses
