Sujets : 2
Is it possible to run Remote SDR with just one HackRF and one Antenna for HalfDuplex Operation?
If the answer is yes, how?
Sujets : 49
No the half-duplex is not possible. It takes to much time for the hackrf to switch from RX to TX and TX to RX.
Sujets : 2
Thanks ... do you have any recommendations how to connect two HackRF to one HF antenna and which components are good to use (filter, amplifier for 200W, any other requirements)?
And additional I would need a way to switch to a second VHF antenna for 20cm/7m.
Sujets : 49
Sorry, I don't have a any recommandation for a HF TX.
