Mise à jour des infos par le shelly
J'ai un shelly em gen3, dans mosquito je ne vois qu'une mise à jour toutes les 5 secondes
shellyemg3-b08184e98f8c/events/rpc {"src":"shellyemg3-b08184e98f8c","dst":"shellyemg3-b08184e98f8c/events","method":"NotifyStatus","params":{"ts":1768048576.16,"em1:0":{"act_power":6790.6,"aprt_power":7004.8,"current":30.932,"freq":50.0,"pf":0.98,"voltage":225.5}}}
shellyemg3-b08184e98f8c/events/rpc {"src":"shellyemg3-b08184e98f8c","dst":"shellyemg3-b08184e98f8c/events","method":"NotifyStatus","params":{"ts":1768048581.16,"em1:0":{"act_power":6358.9,"aprt_power":6601.9,"current":29.064,"freq":50.0,"pf":0.97,"voltage":226.2}}}
shellyemg3-b08184e98f8c/events/rpc {"src":"shellyemg3-b08184e98f8c","dst":"shellyemg3-b08184e98f8c/events","method":"NotifyStatus","params":{"ts":1768048584.16,"em1:0":{"act_power":6000.0,"aprt_power":6164.1,"current":27.081,"freq":50.0,"pf":0.98,"voltage":226.6}}}
shellyemg3-b08184e98f8c/events/rpc {"src":"shellyemg3-b08184e98f8c","dst":"shellyemg3-b08184e98f8c/events","method":"NotifyStatus","params":{"ts":1768048590.16,"em1:0":{"act_power":5586.5,"aprt_power":5719.9,"current":24.946,"freq":50.0,"pf":0.98,"voltage":228.3}}}
shellyemg3-b08184e98f8c/events/rpc {"src":"shellyemg3-b08184e98f8c","dst":"shellyemg3-b08184e98f8c/events","method":"NotifyStatus","params":{"ts":1768048595.16,"em1:0":{"act_power":5587.4,"aprt_power":5729.4,"current":24.923,"freq":50.0,"pf":0.98,"voltage":228.8}}}
shellyemg3-b08184e98f8c/events/rpc {"src":"shellyemg3-b08184e98f8c","dst":"shellyemg3-b08184e98f8c/events","method":"NotifyStatus","params":{"ts":1768048599.16,"em1:0":{"act_power":6614.2,"aprt_power":6853.5,"current":30.124,"freq":50.0,"pf":0.97,"voltage":226.6}}}
shellyemg3-b08184e98f8c/events/rpc {"src":"shellyemg3-b08184e98f8c","dst":"shellyemg3-b08184e98f8c/events","method":"NotifyStatus","params":{"ts":1768048605.17,"em1:0":{"act_power":6714.9,"aprt_power":6857.5,"current":30.283,"freq":50.0,"pf":0.98,"voltage":225.4}}}
shellyemg3-b08184e98f8c/events/rpc {"src":"shellyemg3-b08184e98f8c","dst":"shellyemg3-b08184e98f8c/events","method":"NotifyStatus","params":{"ts":1768048610.17,"em1:0":{"act_power":5011.2,"aprt_power":5154.3,"current":22.409,"freq":50.0,"pf":0.97,"voltage":228.8}}}
shellyemg3-b08184e98f8c/events/rpc {"src":"shellyemg3-b08184e98f8c","dst":"shellyemg3-b08184e98f8c/events","method":"NotifyStatus","params":{"ts":1768048614.17,"em1:0":{"act_power":4140.3,"aprt_power":4276.6,"current":18.489,"freq":50.0,"pf":0.97,"voltage":230.2}}}
je ne vois pas de moyen de rendre la fréquence de maj plus rapide...
Vous faites comment avec vos shelly pour descendre à moins d'une seconde ?
J'ai pas le bon shelly ou le routeur ne récupère pas les valeurs au travers de mqtt mais en direct a une fréquence plus haut aupres du shelly ?
Depuis la version 14.21 le Shelly EM gen 3 est supporté par le routeur. Vous pouvez donc configurer le routeur pour qu'il utilise directement le Shelly EM gen 3 comme source de mesure.
(10-01-2026, 02:49 PM)Mike a écrit : Bonjour,
Merci Mike tu saurais me dire quel est intervalle de mesure ? De ce que je vois dans l'interface la donnée est rafraîchie toutes les 2 secondes (car l'interface elle-même est rafraîchie toutes les 2 secondes. Donc la lecture par le routeur est plus fréquente que par mqtt : c'est noté.
Je me réponds à moi même, sur l'écran du routeur solaire, je vois la puissance captée par le shelly changé toutes les secondes donc le rafraîchissement est au max d'1 seconde avec le shelly
Attention les périodes suivantes sont desynchronisées, indépendantes les unes des autres:
- période interrogation Shelly : 300ms + temps de transfert des données
- période de calcule des ouvertures pour piloter le Triac ou les SSR: 200ms
- période d'affichage des données en page d'accueil: 2s
3 visiteur(s)
