J'ai des remontés d'erreur du routeur dans mes log home Assistant.
D'habitude je cherche et modifie mais en ce moment je manque de temps.
Si 'un de vous a la solution?
voici les erreurs :
voici les erreurs :
Citation :première erreur:
Enregistreur: homeassistant.components.mqtt.client
Source: components/mqtt/client.py:1183
intégration: MQTT (documentation, problèmes)
S'est produit pour la première fois: 05:15:21 (8 occurrences)
Dernier enregistrement: 05:30:20
Can't decode payload b'{"name": "Tension M","uniq_id": "routeur_rms_Tension_M","stat_t": "homeassistant/routeur_rms_state","device_class": "voltage","unit_of_meas": "V","unit_class":"voltage",oF\xfc?\xa2E\xfc?larouteur_rms_RTE_Demain"val_tpl": "{{ value_json.Tension_M|default(0)|round(2)}}","device": {"ids":"31abe342a8","name":"Routeur - ECS","mdl":"ESP32 - 31abe342a8","mf":"F1ATB - https://f1atb.fr","hw":"ESP32-D0WD-V3 rev.301","sw":"17.08","cu":"http://192.168.1.45"}, "availability_topic": "homeassistant/routeur_rms/Available"}' on homeassistant/sensor/routeur_rms_Tension_M/config with encoding utf-8 (for <Job None HassJobType.Callback <function async_start.<locals>.async_discovery_message_received at 0x7fdd7a3a47d0>>)
Can't decode payload b'{"name": "Intensit\xc3\xa9 M","uniq_id": "routeur_rms_Intensite_M","stat_t": "homeassistant/routeur_rms_state","device_class": "current","unit_of_meas": "A","unit_class":"current",oF\xfc?\xa2E\xfc?larouteur_rms_RTE_Demain"val_tpl": "{{ value_json.Intensite_M|default(0)|round(2)}}","device": {"ids":"31abe342a8","name":"Routeur - ECS","mdl":"ESP32 - 31abe342a8","mf":"F1ATB - https://f1atb.fr","hw":"ESP32-D0WD-V3 rev.301","sw":"17.08","cu":"http://192.168.1.45"}, "availability_topic": "homeassistant/routeur_rms/Available"}' on homeassistant/sensor/routeur_rms_Intensite_M/config with encoding utf-8 (for <Job None HassJobType.Callback <function async_start.<locals>.async_discovery_message_received at 0x7fdd7a3a47d0>>)
deuxième erreur :
Enregistreur: homeassistant.components.sensor.recorder
Source: components/sensor/recorder.py:416
intégration: Capteur (documentation, problèmes)
S'est produit pour la première fois: 05:15:10 (2 occurrences)
Dernier enregistrement: 05:15:10
Entity sensor.routeur_ecs_routeur_rms_frequence from integration mqtt has state class total_increasing, but its state is not strictly increasing. Triggered by state 49.98 (previous state: 50.01) with last_updated set to 2026-03-07T04:10:32.027492+00:00. Please create a bug report at https://github.com/home-assistant/core/i...3A+mqtt%22
Entity sensor.routeur_ecs_temperature_du_triac from integration mqtt has state class total_increasing, but its state is not strictly increasing. Triggered by state 16.9 (previous state: 17.0) with last_updated set to 2026-03-07T04:11:44.530511+00:00. Please create a bug report at https://github.com/home-assistant/core/i...3A+mqtt%22
