Erreur lors de la compilation
Lorsque j'essaie de compiler Solar_Router_V17_18_station_VE_2_8.ino (toute première installation), j'obtiens une erreur.
Je vous mets une copie de ce que j'obtiens :
Compilation du croquis...
"C:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2405/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/cpp_flags" -w -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/defines" "-IC:\\Users\\ci_fr\\Downloads\\Solar_Router_V17_18_station_VE_2_8\\Solar_Router_V17_18_station_VE_2_8" -iprefix "C:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/include/" "@C:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/flags/includes" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.3-cfea4f7c-v1\\esp32/qio_qspi/include" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\cores\\esp32" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\variants\\esp32" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\WiFi\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\Network\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\ESPmDNS\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\WebServer\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\FS\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\ArduinoOTA\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\Update\\src" "-Ic:\\Users\\ci_fr\\Documents\\Arduino\\libraries\\PubSubClient\\src" "-Ic:\\Users\\ci_fr\\Documents\\Arduino\\libraries\\DallasTemperature" "-Ic:\\Users\\ci_fr\\Documents\\Arduino\\libraries\\UrlEncode\\src" "-Ic:\\Users\\ci_fr\\Documents\\Arduino\\libraries\\EthernetESP32\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\SPI\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\LittleFS\\src" "-Ic:\\Users\\ci_fr\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\ci_fr\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries\\Wire\\src" "-Ic:\\Users\\ci_fr\\Documents\\Arduino\\libraries\\LovyanGFX\\src" "@C:\\Users\\ci_fr\\AppData\\Local\\arduino\\sketches\\F6FE54CF5AA19A7AF9D79E32EA88DE4B/build_opt.h" "@C:\\Users\\ci_fr\\AppData\\Local\\arduino\\sketches\\F6FE54CF5AA19A7AF9D79E32EA88DE4B/file_opts" "C:\\Users\\ci_fr\\AppData\\Local\\arduino\\sketches\\F6FE54CF5AA19A7AF9D79E32EA88DE4B\\sketch\\Solar_Router_V17_18_station_VE_2_8.ino.cpp" -o "C:\\Users\\ci_fr\\AppData\\Local\\arduino\\sketches\\F6FE54CF5AA19A7AF9D79E32EA88DE4B\\sketch\\Solar_Router_V17_18_station_VE_2_8.ino.cpp.o"
Utilisation du fichier déjà compilé: C:\Users\ci_fr\AppData\Local\arduino\sketches\F6FE54CF5AA19A7AF9D79E32EA88DE4B\sketch\CST820.cpp.o
Utilisation du fichier déjà compilé: C:\Users\ci_fr\AppData\Local\arduino\sketches\F6FE54CF5AA19A7AF9D79E32EA88DE4B\sketch\OneWire.cpp.o
Utilisation du fichier déjà compilé: C:\Users\ci_fr\AppData\Local\arduino\sketches\F6FE54CF5AA19A7AF9D79E32EA88DE4B\sketch\Actions.cpp.o
Utilisation du fichier déjà compilé: C:\Users\ci_fr\AppData\Local\arduino\sketches\F6FE54CF5AA19A7AF9D79E32EA88DE4B\sketch\initGT911.cpp.o
In file included from C:\Users\ci_fr\Downloads\Solar_Router_V17_18_station_VE_2_8\Solar_Router_V17_18_station_VE_2_8\Solar_Router_V17_18_station_VE_2_8.ino:406:
C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/wpa_supplicant/esp_supplicant/include/esp_wps.h:99:1: error: C99 designator 'manufacturer' outside aggregate initializer
  99 | }
C:\Users\ci_fr\Downloads\Solar_Router_V17_18_station_VE_2_8\Solar_Router_V17_18_station_VE_2_8\Solar_Router_V17_18_station_VE_2_8.ino:1033:31: note: in expansion of macro 'WPS_CONFIG_INIT_DEFAULT'
1033 | esp_wps_config_t wps_config = WPS_CONFIG_INIT_DEFAULT(ESP_WPS_MODE);  //SR19
C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/wpa_supplicant/esp_supplicant/include/esp_wps.h:99:1: error: C99 designator 'model_number' outside aggregate initializer
  99 | }
C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/wpa_supplicant/esp_supplicant/include/esp_wps.h:99:1: error: C99 designator 'model_name' outside aggregate initializer
  99 | }
C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/wpa_supplicant/esp_supplicant/include/esp_wps.h:99:1: error: C99 designator 'device_name' outside aggregate initializer
  99 | }
C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-cfea4f7c-v1\esp32/include/wpa_supplicant/esp_supplicant/include/esp_wps.h:99:1: error: C99 designator 'pin' outside aggregate initializer
  99 | }
Utilisation de la bibliothèque WiFi version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\WiFi
Utilisation de la bibliothèque Networking version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\Network
Utilisation de la bibliothèque NetworkClientSecure version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\NetworkClientSecure
Utilisation de la bibliothèque ESPmDNS version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\ESPmDNS
Utilisation de la bibliothèque WebServer version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\WebServer
Utilisation de la bibliothèque FS version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\FS
Utilisation de la bibliothèque ArduinoOTA version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\ArduinoOTA
Utilisation de la bibliothèque Update version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\Update
Utilisation de la bibliothèque PubSubClient version 2.8 dans le dossier: C:\Users\ci_fr\Documents\Arduino\libraries\PubSubClient
Utilisation de la bibliothèque DallasTemperature version 4.0.6 dans le dossier: C:\Users\ci_fr\Documents\Arduino\libraries\DallasTemperature
Utilisation de la bibliothèque UrlEncode version 1.0.1 dans le dossier: C:\Users\ci_fr\Documents\Arduino\libraries\UrlEncode
Utilisation de la bibliothèque EthernetESP32 version 1.0.2 dans le dossier: C:\Users\ci_fr\Documents\Arduino\libraries\EthernetESP32
Utilisation de la bibliothèque SPI version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\SPI
Utilisation de la bibliothèque LittleFS version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\LittleFS
Utilisation de la bibliothèque ArduinoJson version 7.4.2 dans le dossier: C:\Users\ci_fr\Documents\Arduino\libraries\ArduinoJson
Utilisation de la bibliothèque Wire version 3.1.1 dans le dossier: C:\Users\ci_fr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.1.1\libraries\Wire
Utilisation de la bibliothèque LovyanGFX version 1.2.21 dans le dossier: C:\Users\ci_fr\Documents\Arduino\libraries\LovyanGFX
exit status 1
Compilation error: exit status 1
Je n'arrive pas à trouver l'origine de ce problème.
Merci par avance de votre aide.
3 visiteur(s)
