Il y a 45 minutes
Dance of Knives feels right at home in Diablo 4 Season 15, Season of Hell's Legacy, which arrived on September 15, 2026, with Patch 3.2.1. The Rogue spins through crowds, keeps moving, and turns each pack into a target. You will notice the difference as soon as you gather suitable D4 items; the build starts quickly, farms smoothly, and still has room to grow when ordinary dungeon runs stop feeling dangerous.
The Damage Loop Is Simpler Than It Looks
Dance of Knives uses charges instead of Energy. Hold the skill, steer through the room, and let the projectiles spread around your character. The channel counts as one cast, which is the key detail. Activate Poison Imbuement first and every knife can carry the effect. Dark Shroud should usually come before the spin, since its protective shadows reduce incoming damage while also helping movement. Dash and Shadow Step give you a quick escape when a boss or elite cuts off your route.
Choose Gear That Supports Your Actual Rotation
The Aspect of Star Shards is a major part of the setup because it widens the attack pattern and makes crowded rooms much easier to clear. Berú of Spellbound Steel adds stronger imbuement results, useful defensive value, and a better chance to trigger large poison damage over time. Do not chase one impressive stat while ignoring the rest. Movement speed, cooldown recovery, critical chance, resistance, and life all matter when you are spending so much time inside enemy groups.
Build area
What to prioritise
Why it matters
Core attack
Dance of Knives charges and area size
More uptime and wider room coverage
Poison package
Poison Imbuement and Lucky Hit
Longer pressure on elites and bosses
Defence
Dark Shroud, life, resistance, dodge
Safer movement through dense packs
Mobility
Dash, Shadow Step, movement speed
Better positioning and faster clear times
Seasonal Choices Reward a Bit of Restraint
Soul Splinters from Waking Nightmare encounters can add serious power, but each choice asks you to give something up. Diablo, Baal, and Mephisto echoes provide access to these socketable gems and their Iconic Powers. A critical chance or attack speed boost looks tempting, yet a defensive option may produce better results in difficult content. Returning items such as Stone of Jordan and Leoric's Crown also deserve testing, especially when your resistances or elemental scaling need help.
Take the Same Rhythm Into High-Tier Content
For routine farming, cast Dark Shroud, trigger Poison Imbuement, and keep spinning through the route. For stronger encounters, slow down near dangerous effects rather than forcing the next pack. The Artificer's Pit can take this setup beyond Tier 120, while the Artificer's Tower tests movement, timing, and target selection. Collect orbs from elite enemies and Goblins, summon the Tower Guardian, and watch your clear time. Small upgrades to d4 mats and gear can make that next push feel far more manageable.
Build area
What to prioritise
Why it matters
Core attack
Poison package
Defence
Mobility
