Il y a 26 minutes
Call of Duty: Modern Warfare 4 arrives on October 23, 2026, with Infinity Ward putting close-range fights under the microscope. The biggest change is the quick finisher, a short first-person takedown that keeps you in the action instead of trapping you in a long cinematic. If you like slipping behind an opponent during a messy push, Modern Warfare 4 Boosting may help you learn the timing, but the real appeal is how much control stays in your hands. You strike, recover, and get your sights back up before the next threat has time to settle.
Close-Range Fights Feel Less Interrupted
Older executions looked dramatic, yet they could turn into a risky pause. A nearby rifleman only needed a second to punish you. MW4 takes a different route. The new animation plays from the operator's view and gets out of the way quickly. It is not just a cosmetic change. You can read the room sooner, move towards cover, or challenge the next target without feeling stuck in a scene. That small shift should matter most in tight corridors, stairwells, and objective rooms where every moment counts.
Weapons Give Each Takedown Its Own Rhythm
The Krait P68, Sang 9mm, 50 GS, and Combat Knife all support the system, but they do not feel identical. A pistol finisher has a different snap from a knife strike. The game also ties the motion to weapon handling, sound, and camera movement through Ballistic Authority. Players will notice it when sprinting into a close fight, making the takedown, then aiming down sights almost at once. The usual reward is 250 XP, though the bigger prize is keeping your position alive.
Movement Is the Setup, Not the Bonus
Quick finishers work best when they begin with smart movement. MW4 steps away from the floating, all-direction style seen in some recent entries. Mantling, pipe climbing, and the Supine Slide give you practical ways to reach an exposed angle. You will probably find yourself planning the approach before thinking about the strike.
Use cover to break the enemy's view before closing in.
Listen for reloads and footsteps rather than rushing every opening.
Leave a route out after the takedown, especially near an objective.
Why Practice Will Matter
The strongest players will not force this move whenever an opponent turns away. They will wait for the right gap, check the nearby lanes, and choose a finisher only when it improves their position. That restraint could make the system useful in ranked play rather than a flashy distraction. During the beta, expect players to test animation speed, weapon reach, and recovery time in every close map. Those details may shape loadouts just as much as recoil or sprint speed. For players building a reliable routine, CoD MW4 Redeem Codes can add useful extras while they focus on mastering the new rhythm.
