Gluco-Monitor offers real-time, continuous glucose tracking. Using data from FreeStyle Libre 2 or 3 sensors, it displays glucose levels on a dedicated screen for easy monitoring of yourself or a loved one. Perfect for a nightstand or a busy living space, it keeps your data visible at a glance.
Gluco-Monitor is an open-source DIY project.
How it Works
- The FreeStyle Libre sensor sends glucose readings via Bluetooth to the patient’s smartphone using the FreeStyle Libre 3 app. The app then uploads these readings to the LibreView Cloud (Abbott’s server).
- Similar to the LibreLinkUp app, which family members use to monitor levels, Gluco-Monitor connects via Wi-Fi to the LibreView Cloud to periodically retrieve the latest data.
Build Details
Screen : The 3.2-inch display can be purchased online for approximately 20€, preferably directly from China via AliExpress.
Power Supply : Uses a standard USB-C smartphone charger.
Software : The firmware can be installed in 2 minutes directly from this website.
Prerequisites : You must first set up a LibreLinkUp account on a smartphone. The same login and password will be used for Gluco-Monitor.
Disclaimer
Gluco-Monitor is designed to display data from your FreeStyle Libre 2/3 continuous glucose monitoring (CGM) system, as stored in the Abbott database.
Please note that this software is not officially supported by Abbott or FreeStyle and was developed through reverse engineering and online research.
FreeStyle, Libre, LibreView, LibreLinkUp, and related brand marks are trademarks of Abbott Diabetes Care Inc. in various jurisdictions. All other trademarks are the property of their respective owners. This software is not affiliated with Abbott Diabetes Care, Inc. or any of its subsidiaries.
Gluco-Monitor should not be used for medical diagnosis or treatment, nor should it be used as a substitute for professional medical advice. Individual symptoms and circumstances may vary.
Gluco-Monitor is a personal DIY project and is open-source under the MIT License.
Details and source code are available on the websites :
