(Hier, 06:49 AM)F1ATB a écrit : (Hier, 06:24 AM)F1ATB a écrit : It seems the monitor reset all the times.
Are you able to access the message page byswaping the screen on the right or the left. May be , the messages will tell you the reason.
One possible explanation. Your power supply is not powerfull enough. When there are some peaks of current during wifi transmission, the voltage drop down. Change the power supply by a stronger one. Minimum 2A 5V.
Thank you about your quick answer André!!!
I´ve tried with different power suplys and wires, and I´ve the same result.
I connected to my laptop (because in your web, appart of install, you can connect, see the logs, copy, etc...
I´ve copyed two or three loops (I putted XXXXX XXXXX and YYYYY YYYYY in my wifi and LibreLink User and Passwords, but all the rest of the text is as appears in the logs.
I hope this can help to solve my problem. (It´s extrange too because when LibreLinnkUP connects, the resoult of the date reading is 0... O_0
[08:55:02]IMPROV Commande série: IMPROV Valeur:
[08:55:02]Hostname : GlucoMonit-5458544
[08:55:02]Inicialización de WiFi
[08:55:02]Escaneando redes
[08:55:05]Escaneo finalizado
[08:55:05]19 redes encontradas
[08:55:05]|Nr| SSID | RSSI | MAC | Channel |
[08:55:05]| 1|IVITERI | -52 dBm |98:42:65:83:B5:8C| 11|
[08:55:05]| 2|MOVISTAR_9B4A | -66 dBm |CC:D4:A1:9F:9B:4B| 11|
[08:55:05]| 3|MIWIFI_fgf3_2G | -85 dBm |34:DA:B7:D5:7C:AD| 6|
[08:55:05]| 4|MOVISTAR_BDAE | -87 dBm |94:91:7F:0C:BD:AF| 1|
[08:55:05]| 5|Livebox6-A1D3 | -87 dBm |1C:F4:3F:34:A1:D2| 6|
[08:55:05]| 6|Gt | -88 dBm |94:B4:0F:76:8B:A3| 1|
[08:55:05]| 7|DIGIFIBRA-zxu5 | -88 dBm |D8:E8:44:90:85:DA| 8|
[08:55:05]| 8|Eventos SpiritHGB | -92 dBm |AC:A3:1E:9F:8B:A1| 1|
[08:55:05]| 9|Eventos SpiritHGB | -93 dBm |94:B4:0F:76:8B:A2| 1|
[08:55:05]|10|MIWIFI_2G_sy6E | -93 dBm |E4:CA:12:C2:F4:F5| 1|
[08:55:05]|11|Spirit Hotel Gran Bilbao | -93 dBm |AC:A3:1E:9F:8B:A0| 1|
[08:55:05]|12|Spirit Hotel Gran Bilbao | -93 dBm |94:B4:0F:76:79:00| 1|
[08:55:05]|13|SmartLife-17B6 | -93 dBm |38:2C:E5:9E:17:B6| 6|
[08:55:05]|14|ADHGB | -94 dBm |AC:A3:1E:9F:8B:A2| 1|
[08:55:05]|15|Spirit Hotel Gran Bilbao | -94 dBm |94:B4:0F:76:8B:A0| 1|
[08:55:05]|16|ADHGB | -94 dBm |94:B4:0F:76:8B:A1| 1|
[08:55:05]|17|Gt | -94 dBm |AC:A3:1E:9F:8B:A3| 1|
[08:55:05]|18|F5C0 | -94 dBm |06:81:75:C5:F5:C2| 6|
[08:55:05]|19|DIGIFIBRA-2H4U-2.4G-ext | -94 dBm |02:16:78:A3:A8:0C| 7|
[08:55:05]Versión: 3.3
[08:55:05]Red WiFi: XXXXX
[08:55:05]Contraseña: XXXXX
[08:55:05]Búsqueda WiFi:XXXXX
[08:55:09].6.6.6.6.6.6.6.0.0.0
[08:55:09]Conectado por WiFi, dirección IP: 192.168.1.151 o GlucoMonit-5458544.local
[08:55:12]Servidor web activo en el puerto 80
[08:55:12]PSRAM: 1
[08:55:12]Free heap: 211332
[08:55:12]Free PSRAM: 7143812
[08:55:12]On demande une nouvelle glycémie...
[08:55:12]Tentative de connexion à LibreLinkUp sur
https://api.libreview.io
[08:55:13]10:54:39 Sin conexión a Libreview, código HTTP: 430
[08:55:55]10:55:25 Voltaje de la fuente de alimentación : 3269 mv (Ecart: 6 mv)
[08:56:55]10:56:25 Voltaje de la fuente de alimentación : 3270 mv (Ecart: 15 mv)
[08:57:13]On demande une nouvelle glycémie...
[08:57:13]Tentative de connexion à LibreLinkUp sur
[08:57:14]Login OK: 4598 caractères
[08:57:14].
[08:57:14]userID: YYYYYYYYYYYYYYY
[08:57:14]pointCountGly:0
[08:57:15]Données connexion: 554 caractères
[08:57:15]10:56:44 Última glucemia conocida: 0 mg/dL el null
[08:57:15]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[08:57:15]
[08:57:15]Core 1 register dump:
[08:57:15]PC : 0x400556d5 PS : 0x00060b30 A0 : 0x820db9c1 A1 : 0x3fcebbd0
[08:57:15]A2 : 0x00000000 A3 : 0xfffffffc A4 : 0x000000ff A5 : 0x0000ff00
[08:57:15]A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00000000 A9 : 0x3fcebc70
[08:57:15]A10 : 0x00000000 A11 : 0x3c11a4e4 A12 : 0x0000000b A13 : 0x3fcebd78
[08:57:15]A14 : 0x3fcebc84 A15 : 0x0000ffff SAR : 0x00000008 EXCCAUSE: 0x0000001c
[08:57:15]EXCVADDR: 0x00000000 LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xffffffff
[08:57:15]
[08:57:15]
[08:57:15]Backtrace: 0x400556d2:0x3fcebbd0 0x420db9be:0x3fcebbe0 0x420250e6:0x3fcebca0 0x42028bf9:0x3fcebd10 0x42029d44:0x3fcebf60 0x4202daa6:0x3fcebfb0 0x42035aa8:0x3fcebfe0 0x4037f0d9:0x3fcec000
[08:57:15]
[08:57:15]
[08:57:15]
[08:57:15]
[08:57:15]ELF file SHA256: 98f644dd3
[08:57:15]
[08:57:15]Rebooting...
[08:57:15]ESP-ROM:esp32s3-20210327
[08:57:15]Build:Mar 27 2021
[08:57:15]rst:0xc (RTC_SW_CPU_RST),boot:0x28 (SPI_FAST_FLASH_BOOT)
[08:57:15]Saved PC:0x4037af7e
[08:57:15]SPIWP:0xee
[08:57:15]mode:DIO, clock div:1
[08:57:15]load:0x3fce2820,len:0x10cc
[08:57:15]load:0x403c8700,len:0xc2c
[08:57:15]load:0x403cb700,len:0x30c0
[08:57:15]entry 0x403c88b8
[08:57:16]LittleFS monté avec succès
[08:57:16]PSRAM correctement initialisée
[08:57:16][ 538][E][esp32-hal-adc.c:208] __analogChannelConfig(): Pin is not configured as analog channel
[08:57:16]TensionAlimentation : 3270 mv (Ecart: 9 mv)
[08:57:16]Lecture du fichier paramètres
[08:57:16]Json reçu:{"ssid":"XXXXX","password":"XXXXXX","hostname":"GlucoMonit-5458544","MyIP":"192.168.1.151","idxFuseau":2,"rotation":1,"libreEmail":"YYYYY@YYYYY.com","librePass":"YYYYYYYYYY","libreZone":"","LuminositeNuit":255,"LaLangue":3,"dexcomUsername":"","dexcomPassword":"","dexcomRegion":"Non-US","sensorType":0,"glucoseUnit":0,"glucoseColor":0,"timeFormat":0}
[08:57:18]Ecran Init
[08:57:22]Hostname : GlucoMonit-5458544
[08:57:22]Inicialización de WiFi
[08:57:22]Escaneando redes
[08:57:26]Escaneo finalizado
[08:57:26]18 redes encontradas
[08:57:26]|Nr| SSID | RSSI | MAC | Channel |
[08:57:26]| 1|IVITERI | -54 dBm |98:42:65:83:B5:8C| 11|
[08:57:26]| 2|MOVISTAR_9B4A | -65 dBm |CC:D4:A1:9F:9B:4B| 11|
[08:57:26]| 3|MOVISTAR_BDAE | -80 dBm |94:91:7F:0C:BD:AF| 1|
[08:57:26]| 4|MIWIFI_fgf3_2G | -85 dBm |34:DA:B7:D5:7C:AD| 6|
[08:57:26]| 5|Eventos SpiritHGB | -88 dBm |AC:A3:1E:9F:8B:A1| 1|
[08:57:26]| 6|Livebox6-A1D3 | -88 dBm |1C:F4:3F:34:A1:D2| 6|
[08:57:26]| 7|ADHGB | -89 dBm |AC:A3:1E:9F:8B:A2| 1|
[08:57:26]| 8|Spirit Hotel Gran Bilbao | -91 dBm |94:B4:0F:76:8B:A0| 1|
[08:57:26]| 9|Gt | -91 dBm |AC:A3:1E:9F:8B:A3| 1|
[08:57:26]|10|DIGIFIBRA-zxu5 | -91 dBm |D8:E8:44:90:85:DA| 8|
[08:57:26]|11|Eventos SpiritHGB | -92 dBm |94:B4:0F:76:8B:A2| 1|
[08:57:26]|12|Gt | -92 dBm |94:B4:0F:76:8B:A3| 1|
[08:57:26]|13|Spirit Hotel Gran Bilbao | -92 dBm |AC:A3:1E:9F:8B:A0| 1|
[08:57:26]|14|SmartLife-17B6 | -93 dBm |38:2C:E5:9E:17:B6| 6|
[08:57:26]|15|ADHGB | -94 dBm |94:B4:0F:76:8B:A1| 1|
[08:57:26]|16|DIGIFIBRA-2H4U-2.4G-ext | -95 dBm |02:16:78:A3:A8:0C| 7|
[08:57:26]|17|84C4 | -95 dBm |16:10:81:F7:84:C6| 11|
[08:57:26]|18|Cudy-9C44 | -96 dBm |F4:A4:54:87:9C:44| 3|
[08:57:26]Versión: 3.3
[08:57:26]Red WiFi: XXXXX
[08:57:26]Contraseña: XXXXX
[08:57:26]Búsqueda WiFi:XXXXX
[08:57:30].6.6.6.6.6.6.6.0.0.0.0
[08:57:30]Conectado por WiFi, dirección IP: 192.168.1.151 o GlucoMonit-5458544.local
[08:57:33]Servidor web activo en el puerto 80
[08:57:33]PSRAM: 1
[08:57:33]Free heap: 211420
[08:57:33]Free PSRAM: 7143804
[08:57:33]On demande une nouvelle glycémie...
[08:57:33]Tentative de connexion à LibreLinkUp sur
[08:57:34]Login OK: 4598 caractères
[08:57:34].
[08:57:34]userID: YYYYYYY
[08:57:34]pointCountGly:0
[08:57:35]Données connexion: 554 caractères
[08:57:35]10:57:04 Última glucemia conocida: 0 mg/dL el null
[08:57:35]
[08:57:35]TrendArrow : 0
[08:57:35]
[08:57:35]targetLow : 0
[08:57:35]targetHigh : 0
[08:57:35]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[08:57:35]
[08:57:35]Core 1 register dump:
[08:57:35]PC : 0x400556d5 PS : 0x00060b30 A0 : 0x820db9c1 A1 : 0x3fcebbd0
[08:57:35]A2 : 0x00000000 A3 : 0xfffffffc A4 : 0x000000ff A5 : 0x0000ff00
[08:57:35]A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00000000 A9 : 0x3fcebc70
[08:57:35]A10 : 0x00000000 A11 : 0x3c11a4e4 A12 : 0x0000000b A13 : 0x3fcebd78
[08:57:35]A14 : 0x3fcebc84 A15 : 0x0000ffff SAR : 0x00000018 EXCCAUSE: 0x0000001c
[08:57:35]EXCVADDR: 0x00000000 LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xffffffff
[08:57:35]
[08:57:35]
[08:57:35]Backtrace: 0x400556d2:0x3fcebbd0 0x420db9be:0x3fcebbe0 0x420250e6:0x3fcebca0 0x42028bf9:0x3fcebd10 0x42029d44:0x3fcebf60 0x4202daa6:0x3fcebfb0 0x42035aa8:0x3fcebfe0 0x4037f0d9:0x3fcec000
[08:57:35]
[08:57:35]
[08:57:35]
[08:57:35]
[08:57:35]ELF file SHA256: 98f644dd3
[08:57:35]
[08:57:35]Rebooting...
[08:57:35]ESP-ROM:esp32s3-20210327
[08:57:35]Build:Mar 27 2021
[08:57:35]rst:0xc (RTC_SW_CPU_RST),boot:0x28 (SPI_FAST_FLASH_BOOT)
[08:57:35]Saved PC:0x4037af7e
[08:57:35]SPIWP:0xee
[08:57:35]mode:DIO, clock div:1
[08:57:35]load:0x3fce2820,len:0x10cc
[08:57:35]load:0x403c8700,len:0xc2c
[08:57:35]load:0x403cb700,len:0x30c0
[08:57:35]entry 0x403c88b8
[08:57:36]LittleFS monté avec succès
[08:57:36]PSRAM correctement initialisée
[08:57:36][ 538][E][esp32-hal-adc.c:208] __analogChannelConfig(): Pin is not configured as analog channel
[08:57:36]TensionAlimentation : 3270 mv (Ecart: 9 mv)
[08:57:36]Lecture du fichier paramètres
[08:57:36]Json reçu:{"ssid":"XXXXX","password":"XXXXX","hostname":"GlucoMonit-5458544","MyIP":"192.168.1.151","idxFuseau":2,"rotation":1,"libreEmail":"YYYYY@YYYYY.com","librePass":"YYYYY","libreZone":"","LuminositeNuit":255,"LaLangue":3,"dexcomUsername":"","dexcomPassword":"","dexcomRegion":"Non-US","sensorType":0,"glucoseUnit":0,"glucoseColor":0,"timeFormat":0}
[08:57:38]Ecran Init
[08:57:42]Hostname : GlucoMonit-5458544
[08:57:42]Inicialización de WiFi
[08:57:42]Escaneando redes
[08:57:46]Escaneo finalizado
[08:57:46]7 redes encontradas
[08:57:46]|Nr| SSID | RSSI | MAC | Channel |
[08:57:46]| 1|IVITERI | -54 dBm |98:42:65:83:B5:8C| 11|
[08:57:46]| 2|MOVISTAR_9B4A | -66 dBm |CC:D4:A1:9F:9B:4B| 11|
[08:57:46]| 3|MOVISTAR_BDAE | -79 dBm |94:91:7F:0C:BD:AF| 1|
[08:57:46]| 4|MIWIFI_fgf3_2G | -84 dBm |34:DA:B7:D5:7C:AD| 6|
[08:57:46]| 5|Livebox6-A1D3 | -86 dBm |1C:F4:3F:34:A1:D2| 6|
[08:57:46]| 6|DIGIFIBRA-zxu5 | -88 dBm |D8:E8:44:90:85:DA| 8|
[08:57:46]| 7|Cudy-9C44 | -94 dBm |F4:A4:54:87:9C:44| 3|
[08:57:46]Versión: 3.3
[08:57:46]Red WiFi: XXXXX
[08:57:46]Contraseña: XXXXX
[08:57:46]Búsqueda WiFi:XXXXX
[08:57:49].6.6.6.6.6.6.6.6.0.0
[08:57:49]Conectado por WiFi, dirección IP: 192.168.1.151 o GlucoMonit-5458544.local
[08:57:52]Servidor web activo en el puerto 80
[08:57:52]PSRAM: 1
[08:57:52]Free heap: 211808
[08:57:52]Free PSRAM: 7143812
[08:57:52]On demande une nouvelle glycémie...
[08:57:52]Tentative de connexion à LibreLinkUp sur
[08:57:54]Login OK: 4598 caractères
[08:57:54].
[08:57:54]userID: YYYYYYY
[08:57:54]pointCountGly:0
[08:57:54]Données connexion: 554 caractères
[08:57:54]10:57:24 Última glucemia conocida: 0 mg/dL el null
[08:57:54]
[08:57:54]TrendArrow : 0
[08:57:54]
[08:57:54]targetLow : 0
[08:57:54]targetHigh : 0
[08:57:55]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[08:57:55]
[08:57:55]Core 1 register dump:
[08:57:55]PC : 0x400556d5 PS : 0x00060b30 A0 : 0x820db9c1 A1 : 0x3fcebc60
[08:57:55]A2 : 0x00000000 A3 : 0xfffffffc A4 : 0x000000ff A5 : 0x0000ff00
[08:57:55]A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00000000 A9 : 0x3fcebd00
[08:57:55]A10 : 0x00000000 A11 : 0x3c11a4e4 A12 : 0x0000000b A13 : 0x3fcebe08
[08:57:55]A14 : 0x3fcebd14 A15 : 0x0000ffff SAR : 0x00000008 EXCCAUSE: 0x0000001c
[08:57:55]EXCVADDR: 0x00000000 LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xffffffff
[08:57:55]
[08:57:55]
[08:57:55]Backtrace: 0x400556d2:0x3fcebc60 0x420db9be:0x3fcebc70 0x420250e6:0x3fcebd30 0x42028bf9:0x3fcebda0 0x42029d44:0x3fcebff0 0x4202daa6:0x3fcec040 0x42035aa8:0x3fcec070 0x4037f0d9:0x3fcec090
[08:57:55]
[08:57:55]
[08:57:55]
[08:57:55]
[08:57:55]ELF file SHA256: 98f644dd3
[08:57:55]
[08:57:55]Rebooting...
[08:57:55]ESP-ROM:esp32s3-20210327
[08:57:55]Build:Mar 27 2021
[08:57:55]rst:0xc (RTC_SW_CPU_RST),boot:0x28 (SPI_FAST_FLASH_BOOT)
[08:57:55]Saved PC:0x40383a33
[08:57:55]SPIWP:0xee
[08:57:55]mode:DIO, clock div:1
[08:57:55]load:0x3fce2820,len:0x10cc
[08:57:55]load:0x403c8700,len:0xc2c
[08:57:55]load:0x403cb700,len:0x30c0
[08:57:55]entry 0x403c88b8
[08:57:55]LittleFS monté avec succès
[08:57:56]PSRAM correctement initialisée
[08:57:56][ 538][E][esp32-hal-adc.c:208] __analogChannelConfig(): Pin is not configured as analog channel
[08:57:56]TensionAlimentation : 3270 mv (Ecart: 9 mv)
[08:57:56]Lecture du fichier paramètres
[08:57:56]Json reçu:{"ssid":"XXXXXX","password":"XXXXX","hostname":"GlucoMonit-5458544","MyIP":"192.168.1.151","idxFuseau":2,"rotation":1,"libreEmail":"YYYYY@YYYYY.com","librePass":"Suputisimamadre1122-","libreZone":"","LuminositeNuit":255,"LaLangue":3,"dexcomUsername":"","dexcomPassword":"","dexcomRegion":"Non-US","sensorType":0,"glucoseUnit":0,"glucoseColor":0,"timeFormat":0}
[08:57:57]Ecran Init
[08:58:02]Hostname : GlucoMonit-5458544
[08:58:02]Inicialización de WiFi
[08:58:02]Escaneando redes
[08:58:05]Escaneo finalizado
[08:58:05]17 redes encontradas
