Shelly Pro EM connection failed
Je suis sur un ESP WROOM avec la version 17_30.
J'ai récemment mis à jour mon Shelly Prom Em avec cette version 20260710-101108/2.0.0-g87fbfa4
Depuis le routeur n'arrive pas à se connecter alors que lors que je me connecte directement au shelly via http j'ai bien les informations.
Avec rpc/Shelly.GetDeviceInfo
{"name":null,"id":"shellyproem50-xxxxxxxx","mac":"xxxxxxxx","slot":0,"model":"SPEM-002CEBEU50","gen":2,"fw_id":"20260710-101108/2.0.0-g87fbfa4","ver":"2.0.0","app":"ProEM","auth_en":false,"auth_domain":null,"provision":"complete","enhanced_security":false}
Puis
rpc/Shelly.GetStatus:
{"ble":{},"bthome":{},"cloud":{"connected":true},"em1:0":{"id":0,"voltage":233.0,"current":0.536,"act_power":47.5,"aprt_power":125.2,"pf":0.43,"freq":50.0,"calibration":"factory"},"em1:1":{"id":1,"voltage":233.1,"current":0.000,"act_power":0.0,"aprt_power":4.7,"pf":0.00,"freq":50.0,"calibration":"factory"},"em1data:0":{"id":0,"total_act_energy":9445275.80,"total_act_ret_energy":398938.86},"em1data:1":{"id":1,"total_act_energy":2287108.04,"total_act_ret_energy":660630.02},"eth":{"ip":null,"ip6":null},"modbus":{},"mqtt":{"connected":false},"switch:0":{"id":0,"source":"init","tag":null, "output":false,"temperature":{"tC":45.8, "tF":114.4}},"sys":{"mac":"xxxxxxxx","restart_required":false,"time":"18:09","unixtime":1794564580,"last_sync_ts":1794563914,"uptime":678,"ram_size":264872,"ram_free":116060,"ram_min_free":102592,"fs_size":524288,"fs_free":159744,"cfg_rev":22,"kvs_rev":0,"schedule_rev":0,"webhook_rev":0,"btrelay_rev":0,"available_updates":{},"reset_reason":3,"utc_offset":28800},"wifi":{"sta_ip":"192.168.1.48","status":"got ip","ssid":"xxxxx","channel":6,"rssi":-54,"bssid":"34:27:92:34:ed:3a","sta_ip6":["fe80::3698:7aef:fe55:520","2a01:e0a:81e3:aba0:3698:7aff:fe45:520"]},"ws":{"connected":false}}
Il y a t'il des évolutions qui pourraient expliquer ce problème de connection ?
L'ip du Shelly n'a pas changé ?
Non, l'IP n'a pas  changée et est toujours bonne, c'est celle que j'ai utilisée pour avoir les données json remontées.
Quels sont les symptômes coté routeur ? Que contient la page des données brutes ?
Ceci:
Le Shelly et l'ESP sont connectés sur le même réseau? il n'y a pas un répéteur ou autre équipement qui pourrait interférer ?
D'après le message d'erreur, bien que l'ip soit bonne le routeur n'arrive pas a effectuer une requête sur le Shelly.
Ce n'est pas lié au contenu du JSON retourné, c'est la requête qui ne fonctionne pas.
(Hier, 08:48 PM)Mike a écrit : Le Shelly et l'ESP sont connectés sur le même réseau? il n'y a pas un répéteur ou autre équipement qui pourrait interférer ?
Merci, je vais fouiller sur le problème de connexion.
Normalement tout est sur le même réseau, je vais tout rechecker car j'ai effectivement plusieurs réseau qui trainent.
Comme j'ai un autre Shelly j'ai testé  de m'y connecter cela fonctionnait.
J'ai ensuite fait un reset usine du Shelly Pro EM ou la connexion ne s'établissait pas.
Depuis cela fonctionne !! va savoir  !
Merci pour votre aide en tout cas.
