27-09-2025, 06:07 AM
Mon Domoticz ne sais plus lire les trames du linky depuis le passage en mode stardart, j'ai bien modifier la vitesse mais ça ne fonctionne plus, avez vous une idée sur le sujet?
J'utilise un BuBus 001 Device 005: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port avec un montage basé sur un octocoupleur qui fonctionne depuis des années.
udevadm info -a -n /dev/ttyUSB0
Udevadm info starts with the device specified by the devpath and then
walks up the chain of parent devices. It prints for every device
found, all possible attributes in the udev rules key format.
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
looking at device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB0/tty/ttyUSB0':
KERNEL=="ttyUSB0"
SUBSYSTEM=="tty"
DRIVER==""
ATTR{power/control}=="auto"
ATTR{power/runtime_active_time}=="0"
ATTR{power/runtime_status}=="unsupported"
ATTR{power/runtime_suspended_time}=="0"
looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB0':
KERNELS=="ttyUSB0"
SUBSYSTEMS=="usb-serial"
DRIVERS=="pl2303"
ATTRS{port_number}=="0"
ATTRS{power/control}=="auto"
ATTRS{power/runtime_active_time}=="0"
ATTRS{power/runtime_status}=="unsupported"
ATTRS{power/runtime_suspended_time}=="0"
looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0':
KERNELS=="1-1.4:1.0"
SUBSYSTEMS=="usb"
DRIVERS=="pl2303"
ATTRS{authorized}=="1"
ATTRS{bAlternateSetting}==" 0"
ATTRS{bInterfaceClass}=="ff"
ATTRS{bInterfaceNumber}=="00"
ATTRS{bInterfaceProtocol}=="00"
ATTRS{bInterfaceSubClass}=="00"
ATTRS{bNumEndpoints}=="03"
ATTRS{supports_autosuspend}=="1"
looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4':
KERNELS=="1-1.4"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{avoid_reset_quirk}=="0"
ATTRS{bConfigurationValue}=="1"
ATTRS{bDeviceClass}=="00"
ATTRS{bDeviceProtocol}=="00"
ATTRS{bDeviceSubClass}=="00"
ATTRS{bMaxPacketSize0}=="64"
ATTRS{bMaxPower}=="100mA"
ATTRS{bNumConfigurations}=="1"
ATTRS{bNumInterfaces}==" 1"
ATTRS{bcdDevice}=="0300"
ATTRS{bmAttributes}=="80"
ATTRS{busnum}=="1"
ATTRS{configuration}==""
ATTRS{devnum}=="5"
ATTRS{devpath}=="1.4"
ATTRS{devspec}=="(null)"
ATTRS{idProduct}=="2303"
ATTRS{idVendor}=="067b"
ATTRS{ltm_capable}=="no"
ATTRS{manufacturer}=="Prolific Technology Inc."
ATTRS{maxchild}=="0"
ATTRS{power/active_duration}=="1571838574"
ATTRS{power/autosuspend}=="2"
ATTRS{power/autosuspend_delay_ms}=="2000"
ATTRS{power/connected_duration}=="1571838574"
ATTRS{power/control}=="on"
ATTRS{power/level}=="on"
ATTRS{power/persist}=="1"
ATTRS{power/runtime_active_time}=="27341642089"
ATTRS{power/runtime_status}=="active"
ATTRS{product}=="USB-Serial Controller"
ATTRS{quirks}=="0x0"
ATTRS{removable}=="removable"
ATTRS{rx_lanes}=="1"
ATTRS{speed}=="12"
ATTRS{tx_lanes}=="1"
ATTRS{urbnum}=="-1056590199"
ATTRS{version}==" 1.10"
looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1':
KERNELS=="1-1"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{bDeviceClass}=="09"
ATTRS{bDeviceProtocol}=="02"
ATTRS{bMaxPower}=="2mA"
ATTRS{bcdDevice}=="0200"
ATTRS{bmAttributes}=="e0"
ATTRS{busnum}=="1"
ATTRS{devnum}=="2"
ATTRS{devpath}=="1"
ATTRS{idProduct}=="9514"
ATTRS{idVendor}=="0424"
ATTRS{maxchild}=="5"
ATTRS{power/active_duration}=="1571841294"
ATTRS{power/autosuspend}=="0"
ATTRS{power/autosuspend_delay_ms}=="0"
ATTRS{power/connected_duration}=="1571841294"
ATTRS{power/level}=="auto"
ATTRS{power/runtime_active_time}=="27341644621"
ATTRS{removable}=="unknown"
ATTRS{speed}=="480"
ATTRS{urbnum}=="53"
ATTRS{version}==" 2.00"
looking at parent device '/devices/platform/soc/3f980000.usb/usb1':
KERNELS=="usb1"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{authorized_default}=="1"
ATTRS{bDeviceProtocol}=="01"
ATTRS{bMaxPower}=="0mA"
ATTRS{bcdDevice}=="0601"
ATTRS{busnum}=="1"
ATTRS{devnum}=="1"
ATTRS{devpath}=="0"
ATTRS{idProduct}=="0002"
ATTRS{idVendor}=="1d6b"
ATTRS{interface_authorized_default}=="1"
ATTRS{manufacturer}=="Linux 6.1.23-v7+ dwc_otg_hcd"
ATTRS{maxchild}=="1"
ATTRS{power/active_duration}=="1571841454"
ATTRS{power/connected_duration}=="1571841454"
ATTRS{power/runtime_active_time}=="27341645225"
ATTRS{product}=="DWC OTG Controller"
ATTRS{serial}=="3f980000.usb"
ATTRS{speed}=="480"
ATTRS{urbnum}=="27"
looking at parent device '/devices/platform/soc/3f980000.usb':
KERNELS=="3f980000.usb"
SUBSYSTEMS=="platform"
DRIVERS=="dwc_otg"
ATTRS{busconnected}=="Bus Connected = 0x1"
ATTRS{buspower}=="Bus Power = 0x1"
ATTRS{bussuspend}=="Bus Suspend = 0x0"
ATTRS{devspeed}=="Device Speed = 0x0"
ATTRS{driver_override}=="(null)"
ATTRS{enumspeed}=="Device Enumeration Speed = 0x1"
ATTRS{fr_interval}=="Frame Interval = 0x1d4b"
ATTRS{ggpio}=="GGPIO = 0x00000000"
ATTRS{gnptxfsiz}=="GNPTXFSIZ = 0x01000306"
ATTRS{gotgctl}=="GOTGCTL = 0x001c0001"
ATTRS{gpvndctl}=="GPVNDCTL = 0x00000000"
ATTRS{grxfsiz}=="GRXFSIZ = 0x00000306"
ATTRS{gsnpsid}=="GSNPSID = 0x4f54280a"
ATTRS{guid}=="GUID = 0x2708a000"
ATTRS{gusbcfg}=="GUSBCFG = 0x20001700"
ATTRS{hcd_frrem}=="HCD Dump Frame Remaining"
ATTRS{hcddump}=="HCD Dump"
ATTRS{hnp}=="HstNegScs = 0x0"
ATTRS{hnpcapable}=="HNPCapable = 0x1"
ATTRS{hprt0}=="HPRT0 = 0x00001005"
ATTRS{hptxfsiz}=="HPTXFSIZ = 0x02000406"
ATTRS{hsic_connect}=="HSIC Connect = 0x1"
ATTRS{inv_sel_hsic}=="Invert Select HSIC = 0x0"
ATTRS{mode}=="Mode = 0x1"
ATTRS{mode_ch_tim_en}=="Mode Change Ready Timer Enable = 0x0"
ATTRS{rd_reg_test}=="Time to read GNPTXFSIZ reg 10000000 times: 1210 msecs (121 jiffies)"
ATTRS{regdump}=="Register Dump"
ATTRS{regoffset}=="0xffffffff"
ATTRS{regvalue}=="invalid offset"
ATTRS{rem_wakeup_pwrdn}==""
ATTRS{remote_wakeup}=="Remote Wakeup Sig = 0 Enabled = 0 LPM Remote Wakeup = 0"
ATTRS{spramdump}=="SPRAM Dump"
ATTRS{srp}=="SesReqScs = 0x1"
ATTRS{srpcapable}=="SRPCapable = 0x1"
ATTRS{wr_reg_test}=="Time to write GNPTXFSIZ reg 10000000 times: 370 msecs (37 jiffies)"
looking at parent device '/devices/platform/soc':
KERNELS=="soc"
DRIVERS=="simple-pm-bus"
looking at parent device '/devices/platform':
KERNELS=="platform"
SUBSYSTEMS==""
DRIVERS==""
2025-09-27 05:10:35.479 Error: Electricite: CRC check failed on Teleinfo line 'EF @CU@ NSD "0' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:35.543 Error: Electricite: CRC check failed on Teleinfo line ' 1731!0# BIPN A% 6"0 021%8!' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:35.559 Error: Electricite: CRC check failed on Teleinfo line 'SINSTI 00 08' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:35.733 Error: Electricite: CRC check failed on Teleinfo line 'M000000 0QPI!A11$07 6 UCASN E"09"0000 010100 1 AQ!%12 00 232 CTE 3 2' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:35.799 Status: Electricite: CRC check mode set to 1
2025-09-27 05:10:35.813 Error: Electricite: CRC check failed on Teleinfo line 'RELAIS 000' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:35.826 Error: Electricite: CRC check failed on Teleinfo line 'DF0' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:35.840 Error: Electricite: CRC check failed on Teleinfo line 'JOU0' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:36.076 Error: Electricite: CRC check failed on Teleinfo line '00 # 0 0 00"22 00 NEIL NO PA NNALE NNDL NONUDIE,0040039VA0 BAAA10" 0# AGF DMPO ' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:36.395 Error: Electricite: CRC check failed on Teleinfo line 'D 18&# AS !00060NF2 2%"15 @ESF03 0 02 0 04103100 00 C0 0!50AS 70 00 ESF08 000000 A 000 0 1 0 0" S1 "3%6AD"00258 BA3 25#"' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:36.509 Error: Electricite: CRC check failed on Teleinfo line 'ESD0 0$0 00 11F! 0&8! AA0000?AQ300"6 SRQ$00"520$' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:36.523 Error: Electricite: CRC check failed on Teleinfo line 'RMC 0 ' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:36.643 Error: Electricite: CRC check failed on Teleinfo line 'BM 00P0$0 1 9033!03#BIXN1"02&"05 0 0' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:36.724 Error: Electricite: CRC check failed on Teleinfo line 'C001970 0 SAX!2%26$80'060 ' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:37.176 Error: Electricite: CRC check failed on Teleinfo line 'CASN 00 0 008 29"00 0 1 UO12%7 !02"00 ISAE <M"28!92046RE 00 0$ #0 + 00 00 2"40NNUANNQE EAL NONUDIE N 100 1VA "@A2! 3 BNF TEMPO ' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:37.285 Error: Electricite: CRC check failed on Teleinfo line 'AF00"205@AF300!#37!7' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:37.306 Error: Electricite: CRC check failed on Teleinfo line 'EAC04 000 ' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:37.368 Error: Electricite: CRC check failed on Teleinfo line '0 01 $001 AF000 00(' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:37.410 Error: Electricite: CRC check failed on Teleinfo line 'AF 0000)ASF 00 00' using both modes 1 and 2. Line skipped.
2025-09-27 05:10:37.494 Error: Electricite: CRC check failed on Teleinfo line 'A0 0 00 326 @2 0"%BAD0 31#9' using both modes 1 and 2. Line skipped.
cat /tmp/teleinfo_dump.txt
BF001 0 00! 0396 R 26"SIM!0"0RC#4C
ASTC 037CXSN 0 00000#!! 2"00015 NSA000 <
MAXIN E250060 0000
CNE%9" 000 0 C !16 0 0
JOUB !N1 09&A Q2 " @I"20 1257 RLAA0 C
NJOURF+1 PJO 0 0 0"20 0 NOTAE NONUTILE N
QAANAL NOTIE NONETL
NT DPO 0!00030 " A1 ' 73
S 0 00( 0!3#66EASF 0040!00108 6 07!0
AF80000 0EAC0900 0 00 00"0006#A@0 0!50B
AC3 2!9 EASD0$0 000 00110 111 2 0"A300"6SRQ$ 2%5![
IRMC0 UBM1 230
REF @UC 6
IAN!%2&"508 02!SINST 810001
007 0000 IA)A516!$0 00!
CCACNE"0 0 0 08
010 3 0"&_IO121272 "3
EC001$2%C70!2MC1 @S A
TB0!N
NJOURF 00
NOUB+ PJ0 0! 0 20 NNUA NONUTILE
KERNEL=="ttyUSB0"
SUBSYSTEM=="tty"
DRIVER==""
KERNELS=="ttyUSB0"
DRIVERS=="pl2303"
SUBSYSTEMS=="usb"
DRIVERS=="pl2303"
KERNELS=="1-1.4"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{busnum}=="1"
ATTRS{devnum}=="5"
ATTRS{speed}=="12"
KERNELS=="1-1"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{busnum}=="1"
ATTRS{devnum}=="2"
ATTRS{devpath}=="1"
ATTRS{speed}=="480"
ATTRS{urbnum}=="53"
KERNELS=="usb1"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{busnum}=="1"
ATTRS{devnum}=="1"
ATTRS{devpath}=="0"
ATTRS{speed}=="480"
ATTRS{urbnum}=="27"
DRIVERS=="dwc_otg"
KERNELS=="soc"
KERNELS=="platform"
SUBSYSTEMS==""
DRIVERS==""
MAXIN E250060 0000
QAANAL NOTIE NONETL
IRMC0 UBM1 230
REF @UC 6
CCACNE"0 0 0 08
TB0!N
NJOURF 00
