U4GM's Monopoly GO Guide to Sticker Boom Rewards
Sticker Boom rewards a little patience, but the useful part is knowing what to leave untouched. I usually start by checking every reward screen before collecting anything, especially when I am also following a Monopoly Go Partners Event. A few saved packs can make a noticeable difference, so there is no need to grab every prize the moment it appears.
Read the Event Tracks Before Claiming
Daily Quick Wins are easy to overlook. Finish the tasks as normal, then pause when the final prize includes stickers. Leaving that reward on the screen gives you something useful to collect once Sticker Boom begins. The same idea works with tournaments and limited-time events. Check the milestone path first. If a later step offers a blue or purple pack, it may be worth stopping just before that point instead of spending dice to rush ahead.
Choose the Rewards That Matter Most
Not every prize needs the same treatment. Cash, dice, and small currency bundles can usually be collected whenever you need them. Sticker packs deserve more thought. Save the larger packs where possible, but do not put yourself in a difficult position just to protect one ordinary reward. A practical approach is to review the track, mark the valuable milestones mentally, and return when the event window is active. That keeps your progress moving without wasting the best collection opportunity.
Turn Duplicate Stars Into Better Timing
Your duplicate stickers still have value because they add stars to your total. Rather than opening a Sticker Vault straight away, let those stars build for a while. When Sticker Boom is live, use the Vault if its contents include eligible packs. Before opening it, check the available options and make sure you are comfortable with the exchange. A little patience here can turn a routine Vault opening into a much stronger set of sticker pulls.
Prepare the Board Before You Collect
Board preparation can help you create another collection chance during the event. Build hotels when it makes sense, keep some cash available, and avoid clearing every property too early. The Color Wheel may then appear while Sticker Boom is running, giving you another route to sticker packs. I find it helpful to keep a short checklist nearby.
Finish Quick Wins but leave a sticker reward unclaimed.
Review tournament and event milestones before taking a major pack.
Save enough duplicate stars for a well-timed Vault opening.
Set up hotels and collect board rewards during the active window.
Once the event starts, collect in a sensible order rather than tapping through everything at once. Take the saved daily reward first, then consider milestone packs and the Vault. Keep a little room for board rewards as well. This routine feels less rushed, and it helps you make better use of the short Sticker Boom window. If you are also planning purchases or event progress, compare your timing with the Monopoly Go Partners Event for sale options before making a decision.
