Nouvelle version V_9.03_RMS du routeur
Cela a fonctionner avec une autre board! Dois je qd meme augmenter le schema a 1,9M?
Allez sur Outils-->Parttion Scheme-->Minimal SPIFFS(1.9MB..)
Sketch uses 1298781 bytes (99%) of program storage space. Maximum is 1310720 bytes.
Global variables use 103260 bytes (31%) of dynamic memory, leaving 224420 bytes for local variables. Maximum is 327680 bytes.
"/Users/xdealmeida/Library/Arduino15/packages/esp32/tools/esptool_py/4.6/esptool" --chip esp32 --port "/dev/cu.usbserial-0001" --baud 115200  --before default_reset --after hard_reset write_flash  -z --flash_mode keep --flash_freq keep --flash_size keep 0x1000 "/private/var/folders/v1/0f8fr1450kz2_mlt8xkp2yfm0000gn/T/arduino/sketches/5055ED93C0D6DDCA94E1A016F6E11E5D/Solar_Router_V9_03_RMS.ino.bootloader.bin" 0x8000 "/private/var/folders/v1/0f8fr1450kz2_mlt8xkp2yfm0000gn/T/arduino/sketches/5055ED93C0D6DDCA94E1A016F6E11E5D/Solar_Router_V9_03_RMS.ino.partitions.bin" 0xe000 "/Users/xdealmeida/Library/Arduino15/packages/esp32/hardware/esp32/3.0.1/tools/partitions/boot_app0.bin" 0x10000 "/private/var/folders/v1/0f8fr1450kz2_mlt8xkp2yfm0000gn/T/arduino/sketches/5055ED93C0D6DDCA94E1A016F6E11E5D/Solar_Router_V9_03_RMS.ino.bin"
esptool.py v4.6
Serial port /dev/cu.usbserial-0001
Connecting....
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 30:c9:22:d2:12:30
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x0014efff...
Compressed 19744 bytes to 13604...
Writing at 0x00001000... (100 %)
Wrote 19744 bytes (13604 compressed) at 0x00001000 in 1.6 seconds (effective 98.8 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.1 seconds (effective 211.7 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 1005.4 kbit/s)...
Compressed 1305376 bytes to 802776...
Writing at 0x00010000... (2 %)
Writing at 0x00020823... (4 %)
Writing at 0x00030896... (6 %)
Writing at 0x0003c26a... (8 %)
Writing at 0x00043d5b... (10 %)
Writing at 0x00049650... (12 %)
Writing at 0x000522f7... (14 %)
Writing at 0x0005fbcd... (16 %)
Writing at 0x00066ca5... (18 %)
Writing at 0x0006db46... (20 %)
Writing at 0x00074774... (22 %)
Writing at 0x00079c13... (24 %)
Writing at 0x0007f94b... (26 %)
Writing at 0x000851b5... (28 %)
Writing at 0x0008ab0c... (30 %)
Writing at 0x000903f0... (32 %)
Writing at 0x00095734... (34 %)
Writing at 0x0009a8d0... (36 %)
Writing at 0x0009fbf7... (38 %)
Writing at 0x000a5220... (40 %)
Writing at 0x000aa525... (42 %)
Writing at 0x000afe17... (44 %)
Writing at 0x000b5146... (46 %)
Writing at 0x000ba122... (48 %)
Writing at 0x000bf4b9... (51 %)
Writing at 0x000c4652... (53 %)
Writing at 0x000c981f... (55 %)
Writing at 0x000ce825... (57 %)
Writing at 0x000d3c15... (59 %)
Writing at 0x000d99cd... (61 %)
Writing at 0x000dee37... (63 %)
Writing at 0x000e422e... (65 %)
Writing at 0x000e9754... (67 %)
Writing at 0x000ee94d... (69 %)
Writing at 0x000f3e2a... (71 %)
Writing at 0x000f913c... (73 %)
Writing at 0x000fe80a... (75 %)
Writing at 0x00103da5... (77 %)
Writing at 0x0010950b... (79 %)
Writing at 0x0010f22f... (81 %)
Writing at 0x00114b71... (83 %)
Writing at 0x0011d612... (85 %)
Writing at 0x00123ad1... (87 %)
Writing at 0x0012b429... (89 %)
Writing at 0x00130554... (91 %)
Writing at 0x00138449... (93 %)
Writing at 0x0013e5f1... (95 %)
Writing at 0x00143d17... (97 %)
Writing at 0x0014908c... (100 %)
Wrote 1305376 bytes (802776 compressed) at 0x00010000 in 71.4 seconds (effective 146.2 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Non chez moi ca passe avec 99%
Mes ESP32 Fige et je les perds en V9.03 !!!
je comprend pas
J'ai aussi un souci en 9.02 lorsque j'ai deux pages html tournant sur deux "clients" utilisant un ESP32 distant "serveur", lorsque j'ouvre aussi une page html sur le dit serveur. le serveur plante et les clients partent en reset watchdog. solution : ne pas afficher de page HTML appelant le serveur en même temps.
J'y arrive pas avec la V9.03, 02, 01
après plusieurs Install ...
ma led orange clignote pendant 3 min fonctionnement normale
ensuite elle clignote de temp en temp
en me connectant dessus par le web, c'est très lent, il faut attendre 10s pour avoir une page !!! quant elle arrive ...
après un reset, il fonctionne correctement 3 minutes
je suis repassé en V8.09, et ca fonctionne bien !!!
(14-06-2024, 11:15 PM)PhDV61 a écrit : J'ai aussi un souci en 9.02 lorsque j'ai deux pages html tournant sur deux "clients" utilisant un ESP32 distant "serveur", lorsque j'ouvre aussi une page html sur le dit serveur.  le serveur plante et les clients partent en reset watchdog.  solution : ne pas afficher de page HTML appelant le serveur en même temps.
Je n'ai pas ce problème, à moins que je n'aie pas compris la configuration.
J'ai essayé :
- un routeur connecté au Linky (IP..212)
- un routeur Piscine qui cherche les données chez routeur Linky en IP...212
- un routeur Chauffage qui cherche les données chez routeur Linky en IP...212
- Mon PC où j'ouvre 2 pages HTML du routeur Linky en ..212
Malgré toutes ces sollicitations sur le routeur Linky, les pages sont fluides.
Je suis en 9.03
André,
j'ai un routeur Linky, mais que j'utilise comme "référence".
C'est le routeur UxIx3 que j'utilise comme serveur pour mes deux routeurs chauffe-eau.
Avec un 3e routeur clients de l'UxIx3 le problème se pose de manière encore plus criante. le routeur UxIx3 ne répond même plus à une interrogation supplémentaire via PC-page HTML, et plante purement et simplement.
Après "enquête", Le routeur UxIx3 lit le module JSY-MK-333 toutes les 600ms, alors que les données ne sont rafraichies par le module que toutes les 1000ms (c'est dans la doc). J'ai donc augmenté la tempo d'interrogation à 1000ms. Et j'utilise maintenant le routeur Linky pour l'un des chauffe-eau à la place de l'UxIx3. J'ai retrouvé le même fonctionnement qu'avec la V8.09. Il y a donc quelque chose qui est apparu de nouveau avec le changement des bibliothèques, mais j'ai réussi semble t'il à le contourner (sans comprendre la source du problème pour le moment, mais ça marche).
Merci pour tout le temps que tu consacres à tous.
A suivre
Suite : ça plante toujours. Je vais sans doute repartir sur du V8.09
(14-06-2024, 03:56 PM)XabiX a écrit :
(14-06-2024, 03:49 PM)F1ATB a écrit : Redémarrez votre PC et l'IDE Arduino.
Pas mieux. Ne serait pas lié au fait que esptool ne détecte pas la board?
Il doit y avoir un moyen d'avoir plus de traces mais ce message laisserait croire que la board n'est pas correctement supporter par les drivers?
TypeError: argument of type 'NoneType' is not iterable
[7495] Failed to execute script 'esptool' due to unhandled exception!
Failed uploading: uploading error: exit status 1
Dois je changer le lien pour récupérer les fichiers dans IDE?
https://docs.espressif.com/projects/ardu...rduino-ide
d'après ce lien pb: https://forum.arduino.cc/t/my-board-esp3.../1237129/2
PS: J'ai essayé et cela ne change rien. J'ai ajouté le log de la compilation et de l'upload. Je vais essayer avec une autre board car j'en ai pris 5 Sad
Vous allez essayer de forcer l'ESP 32 à passer en mode flashage . En fin de compilation, juste au début du téléchargement, vous appuyez sur boot, vous laissez le doigt sur boot, vous appuyez un petit coup sur reset et vous relâchez boot.
Oui j'ai essayé mais rien à y faire mais vu le prix et que les 4 autres fonctionnent je préfère me faire rembourser cette carte qui m'a l'air défaillante.
Moi aussi je rencontre des lenteurs mais vu que je suis nouveau, je vais continuer à tester/perséverer sur la 9.03 (sachant que je n'ai pas pour l'intant ni de triac ni de relais et juste en source mon Envoy).
Bonsoir à tous,
Je viens de passer ma demi-journée à re-télécharger la version V9.03 sur mes 6 esp (heureusement en OTA), avec la version V3.0.1 des cartes ESP32 et avec la partition Minimal SPIFFS (1.9 MB) . Mon ESP d'entrée est sur Linky.
Cela a fonctionné quelques minutes (3 ou 4) puis la fenêtre de l'ESP Linky s'est de nouveau figée.
Impossible de la refaire afficher correctement et impossible de la télécharger à nouveau en OTA; J'ai dû la reprogrammer en USB pour la rétablir mais que pour un court instant.
Je viens donc de repasser l'ensemble en V9.01 avec les cartes ESP v2.0.17 et en gardant la partition mémoire en Minimal SPIFFS.
J'ai ainsi une occupation mémoire programme de 60% et, dans ces conditions tout fonctionne de nouveau parfaitement.
Je ne comprends pas d'où cela peu provenir surtout que certains ont l'air de fonctionner parfaitement avec cette dernière version.
Peut être à cause de la mesure sur Linky ?
A suivre...
Amicalement
Régis
