On the transmit side, different tone generators are available to tune the transmitter or open relays.
800Hz Tone
Selecting this generator disconnects the microphone and injects a 800Hz audio signal to its maximum. This is useful for testing the maximum power in SSB and the excursion in NBFM.
2 Tones Test – 500 Hz and 1900 Hz
By selecting this generator, we disconnect the microphone and push the audio signal to its maximum with 2 signals of amplitude equal to the maximum possible. This allows the linearity of the transmitter to be tested.
DTMF
A DTMF generator is used to send 2-tone codes. This allows the programming of radio relays.
1750 Hz Tone
Pressing this generator opens some relays.
CTCSS
The definition of transmit frequencies for which a CTCSS signal is desired, can be found in the configurationTX.js file.
Pitch CW
To adjust the / TX / RX offset in CW, you can listen to the corresponding signal by pressing Spot.
Leave a Reply
